Fuel Pump
don't believe him..
you look at his nick, an original fuel pump will be suffice for his needs?
he only runs rich, ron100..:driver:
Bro., all stock, so no need upgrade pump lah! In fact, at the beginning I had problem with the pump. It stops pumping at time, so my mechanic thought pump konk, so he find used one. Fit it time it runs, but off and on it stops. Finally found an ECU guy he say your pump no problem, your ECU failing. Not long later the ECU really konk, then change ECU. The pump still the same one for 15 years dy.
I did try one tank Ron100, like no difference, so back to 95, not even 97.....hhahhahahah
you change original? how bout the cost?
My mechanic bought used one, but still using old one. Bought one still keeping as spare in tool box, not sure after so many years can still use or not.....lol:biggrin:
Ron100 no difference to your car meh? I thought you can boost more aggressively with that.
As mentioned all stock, still at 0.6 stock boost. Car is old, certain parts may not stand up to higher boost.......lol:biggrin:
Haha yeah, if use same boost then no additional power lor, then just use the same ron 95. Unless you remap maybe can make it a bit leaner and therefore slightly better FC, but still risky.
Even boost higher, seems according to mechanic original pump still enough because pressure high enough to supply......:driver:
stutzedward
3,416
561
If you are using stock internals, injectors and fuel mapping, you do not need to upgrade the fuel pump to just increase boost. My Airtrek stock boost was 0.6 bar. I had been driving happily for about 3 years with 1.1 bar of boost daily without a problem. Stock injectors, stock ECU and stock fuel pump.
I only replaced the fuel pump when I bolt on all the Evo mods and dyno tuned to boost at 1.5-1.6 bar.
Therefore in anyway, stock fuel pump is more than enough for stock condition with just boost increased.
Shinjite
864
120
Klang
I am currently using the DW200 fuel pump for my Wira EVO, its very silent and it has gotten even more expensive. Got it from N1 Racing pre-GST was at RM380, now it is more than RM400 ~_~" I used Walbro before, it's freaking noisy
Hi guys, me again.
Ive done a lot of research (most of it online) about modding i.e: exhaust, springs, piston boring, camshafts, etc, but Im never sure how much all these will set me back. Lets get an average price shall we? :biggrin:
How much would all these cost individually? on average?
Full exhaust manifold
Open pod/CAI (not cap ayam one ah :biggrin:)
Piston boring
high cam
adjustable cam pulley
adjustable suspension
Larger brakes
feel free to add more...
