Flip key mod?
UKProton
Oct 31, 2015
12
Derbyshire
Hi there, has anybody made a flip key from their neo key? The key is so long and weak that it gets bent when its in my pocket.
Cheers
Sent from my Che2-L11 using Tapatalk
BFX73
116
13
Cheers
care to show us what do u mean with flip key?
UKProton
12
Derbyshire
---------- Post added at 04:47 PM ---------- 6 hour anti-bump limit - Previous post was at 04:47 PM ----------
Something like that so the key doesn't get bent
BFX73
116
13
ic..saw a few of my frens uses flip key and none of them having issue with em...sorry cant help u further... :)
UKProton
12
Derbyshire
this is my current key and it has got bent several times in my pocket only a matter of time before it snaps
BFX73
116
13
i see...so u need the flip key isnt it?
There is one seller in online site mudah.my.
this seller is from malaysia and i used his product.
you just need to duplicate the key using the blank give,transfer the alarm board and the small immobiliser chip.
i must say the built quality is much better than the oem flip key made for proton suprima.
the picture is my key and my sis key.my sis owns a neo cps model which is soon to sold.
UKProton
12
Derbyshire
Would that flip key case fit my key as the ebay listing for that case shows a different key
Do you mean I can't transfer the electronics?
you have to transfer the electronjc but you have to duplicate the key on the blank provided.do ask the seller if the blank is suitable for satria neo model as the similar one i bought had slight different between my saga blm and my sis neo.everything else is the same.
if not mistaken the key for the saga blm cant even go into the neo key slot due to different design.
sifu out there,
Need your feedback, i wan to know wit this mod does it makes alot of diff???
using a s90 tb, skunk intake. on a p&p head... does it makes lot of diff or shall i just port and used a bigger intake from a mit engine! since those honda parts are pricy....
ps head will be fitted wit rpw valve springs and 288/299 or higher matspeed cams! block standard!
thanks alot guys!
na for life:love::love:!!! he he he:adore::adore::adore:
