s 90, honda intake in 4g93??
93na
597
20
sifu out there,
Need your feedback, i wan to know wit this mod does it makes alot of diff???
using a s90 tb, skunk intake. on a p&p head... does it makes lot of diff or shall i just port and used a bigger intake from a mit engine! since those honda parts are pricy....
ps head will be fitted wit rpw valve springs and 288/299 or higher matspeed cams! block standard!
thanks alot guys!
na for life:love::love:!!! he he he:adore::adore::adore:
oly
823
Lumut
it will make a lot of difference...but u are using stock 93 engine?..81mm flat piston?..no good...at least 82mm hi comp piston...our drag car using mat speeed 288 292...with b16a intake and 62mm tb...82mm piston trim for 4g92 sohc...head is gsr turbo...
4G93NAPower
119
8
Penang
only use vtec manifold when you start to touch the engine internals (big piston, high compression, race cam, pnp) and the manifold is good for high rev and you will see difference but remember to use Super90 throttle body too :burnout:
So the producers given them money so they could buy convertibles and what ended up was everyone getting a BMW 325i convertible. Not suprising with the identical cars, but these cars have all sorts of histories, good and bad. Check out the suprise these guys got from their used cars. It's just a really good poke fun moment for them
YouTube - ‪1980s BMW...
