Any aftermarket brake kit to fit in stock 18" Lancer GT rims?
pwhyze
924
356
1,563
Hmm..instead of aftermarket brake kits, maybe try to fit in bigger OEM calipers from upper range models instead? That would retain the stock look but offer better braking performance though I'm not sure from which would be compatible with the Lancer.
Mitevo7
1,456
179
Any bright suggestion ? Was looking for Airtrek's dual pistons stock caliper or Lancer Sportback 2.4's ... Hope hard its plug and play without customizing the bracket
use Mitsu GTO 4 Pot
Thanks but i am not sure can it hide behind the stock wheels ...
I own an old Proton Iswara manual 1.5. At times, I have problem starting the engine. It gives a tick sound but it doesn't work. I need to turn the key a few times to get it running. My car has already installed with a starter relay long time ago. In fact, I have just replaced a new relay. But the problem still persists.
I read somewhere that by giving a knock on the starter could probably fix the problem; that if the starter has no problem. Could someone tell me where exactly where is the...
