Kancil 850 change engine to l2s or l6?
nurashidnm
Jan 6, 2013
5
Hi All,
I have this Kancil 850 car. It is kind of under powered. I have been reading on changing the system/engine.
I need to know, which engine is ok - performance wise and maintenance wise. Is it l6 turbo or l2s?
Thank you in advance all.
Rashid
go for L2s....easy maintenance because sharing many parts with stock 660 kancil engine....
stock good condition engine power atleast should be able to keep up with old standard 1.6 engine...
up to 120kmh only...beyond that....
agreed with u on the maintenance.
seems like price for engine is quite cheap.
ken yeang
6,617
1,327
120km/hour for mousedeer size car........just be careful there...
thanks danz for the info.
i was about to mention abt my friend turbo kancil but dunno which l2 is he using.
it was l2s then because his was injection.
i must admit its a bit scary during acceleration.
beyond that...depend on what kind of ball the driver have... :rofl:
my friend kena one time while on his way to johor on plus highway...maintain side by side with kancil while at 180km/h...he was driving saga blm at that time....
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
want a peace of mind and a bit of oomph for your kancil?
forget turbo, and get a 1000cc engine fromstoria or duet (same as kelisa/kenari)
with its longer ratio gearbox, 180kmh is possible if you are bonkers enuff
Supra_Fanatics
20,673
3,998
Will parts be hard to source bro? If the 1L engine better than stock Kelisa engine, I think next time can consider :rofl:
But a lot say putting a Myvi K3VE in a kelisa, the front will become heavy. Is it true or need to do something for the extra weight? Guessing the front tyres will worn out faster then.
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
Parts are the same with Kelisa/Kenari... just that the ECU tuned a bit different, lots of otais mentioned ecu for malaysian ej series tuned a bit too safe
I got friends who put in K3 in kelisa/kenari... their main USP is that the engine + crossmembers bolted right back in.. yes it is nose heavy, but they say can use myvi/sirion/yrv front suspensions to cope
but then, all daihatsu/perodua's are nose heavy.. you can see in rally, you can see how hilariously the nose are diving during jumps :rofl:
Supra_Fanatics
20,673
3,998
If that's the case, can bring kelisa to tune the ECU then? Or just replace with Storia's ECU?
Ya, usually that's the case.
btw...if owner didnt want bother much with inspection if doing engine transplant,
i would say buy the l2s complete running engine, then swap everything from l2s except the engine block...
so you got 850cc hybrid turbo engine....BUT...need proper tune and thicker head gasket to lower down the compression....and cant boost too much....
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
one more reason why i recommend jap ones over our own kelisa's.. jap's ones tend to be lower mileage than our own
Supra_Fanatics
20,673
3,998
True, but the OEM engine still running strong to consider a transplant for Storia's. Kena poisoined again :rofl:
i used proton wit e3 engine wit some mod.. currently my car drink ron97 fuel and the result is
RM10/28km or less.. my fren said "ok la tu" but for me not.. how urs evo?
