Proton parts any good?
30
5
1,508
So i just changed my spark plug cable and it costed me rm330 lol. even though i was shocked with the price i just went for it since its proton parts.
question is what justifies it to be at this price? others only priced at around 100rm.
and are other proton parts any good in general? im looking to just buy any other branded parts next time.
Supra_Fanatics
20,673
3,998
My question is where did you change them?
YYC
1,833
939
I guess Proton spark plug cable is better than those rm100 cheap cables anytime. I used those cheap ones and lost a bit performance and only lasted less than 2 years.
30
5
1,508
bought at proton sc and go chg at other workshop since always full. i checked the part number others selling online around same price.
back to topic proton parts any good or not.
30
5
1,508
if the stock ones lasted 8-10 years previously, then it's good :)
brand new genuine ones are good.
my original one in my neo which i bought aug 2010 spoiled. but then i checked the part number of this part online selling around rm100, so i guess its good. hope this new one no need change for 10 years lol.
RM100? I got mine aftermarket brand like around RM50 only. Thought spark plug cable should be ok, but after a year plus it crack and leak....:banghead:
YYC
1,833
939
Genuine Proton parts are good. Just that the price is steep compared to others. Take for example driver side 'Japan Mari' central lock cost RM8xx for Perdana but really smooth operation and long lasting.
---------- Post added at 10:59 AM ---------- 6 hour anti-bump limit - Previous post was at 10:57 AM ----------
RM50 plug cable you got to be kidding me. :eek:
Waiora_ProTuner
619
221
for sure better RM300 proton better than RM100 unknown...
unless you compare item with similar price..
i bought from aftermarket around RM200 last time...still survive after 6 years.
ken yeang
6,617
1,327
rm300 is about alright for proton plug cables. Should last at least 5 years. My uncle's proton cable lasted 20 years, until crack developed on the insulation.....and cause arching and engine judder. He could actually wrap rubber around the cracked cable...and fixed the problem.
For him,
RM300/20 years= 15bucks/year. What more can he ask for?
crazykatak
776
48
Subang Jaya
well..at least check and replace the spark plugs more often. foul plugs leads to ignition coil failure and also might damage the plug cables..
No joke brother. Crack after a year use, some more crack all along the cable. Fitted back the old original cable even better....:biggrin:
cvkit17
2,884
1,354
Why bother? U already bought it. U can now survey good aftermarket parts and compare the prices. And since you are using ori proton part, you don't have to worry whether it is reliable or not. And whether proton parts r good or not, it depends... If your ori cable is the same as the new one, the lifespan would pretty much be the same isn't it? Unless your first ori cables have defects.
30
5
1,508
why i bother because im planning for next time parts to change. and the question was are the parts any good or as good/reliable as aftermarket parts. checked bosch cables are around rm100 -150(ori??)~.
the cables are different between my ori and new.... the part numbers on the cables are different, pricing also different 100~ and 300~.
after checking the new cable is for cps models. i bought my neo baseline model maybe cutdown all cost. but i must admit now throttle i play no need go half way, only quarter press can go already. not sure if placebo but more pick up.
Dear All,
Butt itchy, after few weeks honing in my Lancer with M/T transmission, everything feels good and i am going to take my sweet time to gather turbocharging parts. First, i would need to select turbocharger which i am quite clueless on this. My 4B11 NA engine compression is well ok, above 120 PSI in all cylinders. Compression ratio rated at 10:0:1, will decrease it with thicker head gasket. Below are the list of turbos that i can gather within my reach:
1.) OEM Ralliart TDO4HL-14T...
