Inspira 1.8 4B10 Modification sugestion
zack.my
Jul 10, 2013
42
508
Hello all zth fellow ,all sifu n tuner here..
I own inspira 1.8 m/t 4b10 engine..car.manufacter 2010
Register april 2011..curenly this car clock 45k on millage already..
:deal:
Now already finished change out look (evo 10 look ofcoz)and external like s.rim etc.
So i dicide to upgrade performance this car..
Currenly just change dropin k&n filter n retune the stock ecu..
Except this all in factory setup.
Lastime i just check my hp on dyno at n1 racing sunway
Just for make sure exacly how many hp in there..before dyno i chanhe new eo
And recharger back drop in filter for smooth acelaration and clean rev..
Just get 146hp only:slug:
Now..i want youall suggest me..what a next step?
In my mind wanna to BOT this engine..For gain more power..
But lot of my friend said..just stick to n/a..for peace of mind..
The said this engine got more kuasa terpendam...hahaha..what word to use arr?
So what you suggestion?is it BOT on 4B10 not good?..another choice?
Not rushing..just slowly upgrade
Please sugget me:confused:
zack.my
42
508
u could change to 3,4,6 puck exedy semi or full racing clutch,
or recommended ogura.
Bro danzeterna.. Thanks for suggestion
But for change racing cluth i think it too early.. I mean it like final step
i am right?coz stock cluth for me still thick and very good condition..
But thanks your sugestion bro..put already in my list..
zack.my,
what is your budget?
Bro ken yeang..about budget capital..haha.. Not to much la bro
That why i prefer step by step modification..but for the moment.. Cash ready around 15k in hand
Any suggestion bro?
peeche
395
165
Sin City, MY
15k budget.. high cam.. port & polish.. throttle body.. full exhaust system and engine management system (piggyback/standalone).. if hunger for summore power, source a 4b11 or 4b12 block + high comp pistons. :nurse::nurse::nurse:
ixeo
4,788
3,080
KL, Malaysia
Transplant in Evo X engine.....:driver:
15k can find ker?
With RM15k.. just do bolt on turbo straight. I guarantee if you use RM15k to do turbo vs N/A tuning, confirm the turbo will blow the N/A out of the water on the dyno. Oh, of course if the bolt on turbo do wrongly the engine will also blow a hole on the block.
DanzEterna
15,911
3,371
www.primeperdanaclub.com
15k can find ker?
rm15k maybe can find tsunami evo x.
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
the halfcut shop in ampang I usually go has evo x bodypart & few other parts that can be salvaged from tsunami evo x...he said the engine & gbox cannot be used. but I heard some ppl do sell the halfcut. once got problem no warranty.
If the engine didn't start when its soaked in water, the block and head still can use aren't it?
Or its just my imagination.
4gbanger
Jun 26, 2013
1,958
386
683
Johor/ShahAlam
my 1st car was a turbo kancil salvaged from big flood. the car did has some problem so i need to change the parts one by one. but normal the parts that i need to change was wiring and ecu. other mechanical parts no problem. so if u guys said tsunami'ed evo x, the mechanical parts such as engine, turbo, fmic etc still can be use mah. just that u just plonk back manual gb and get a standalone for new wiring.. hahahah..
zack.my
42
508
15k can find ker?
so u have any suggestion shop do BOT nice and smooth ?
it is true BOT always got bad effect for engine?
right now i just buy supercircuit xtractor,,and full set exzos from hotbit(mid and muffler)..but xtractor not install yet still looking for heat resistance spray and wanna to wrap before install..
ya i think i want to install new ecu...but i have zero about ecu... standalone?piggyback? dont know whats that..witch one suit on my car..stock ecu not ok or what? stock ecu can mapping back right?
mean look like stanalone...
hahha...i am so noob...:confused:
---------- Post added at 05:09 PM ---------- 6 hour anti-bump limit - Previous post was at 05:05 PM ----------
put in my list bro thanks alot..:driver:
4b11 same head 4b10?:confused:
Normally BOT on NA engine get problems when boost too high because the parts are not meant for turbo
ixeo
4,788
3,080
KL, Malaysia
Go GT Auto in Sunway, talk to Toby, tell him your budget RM15k and what can he do.
GT Auto is not cheap, I won't call it affordable like Speedworks. But you can be sure the engine won't blow.
Hi All,
Does anyone know of any shops in the Klang Valley area that do a decent job of spraying/painting brake calipers? Am thinking of having my Wira's calipers sprayed/painted red, have seen the DIY guide postings, but would rather have someone do it for me if the price is reasonable. Thanks
