Planting a 4g93 gsr head into 4g92sohc
luorenzo
Aug 14, 2010
21
7
503
sabah
greetings to all, i wanted to know if i plant a 4g93 turbo head into my little 1.6 engine, can i feel the big power changes ? as i know the 4g93 gsr head valve lifting is far more higher than a 4g93NA type. BY running the engine 4g93 gsr head+4g92 block using the standard sohc ecu set up will it increase lot hp ?
aivenrolx
250
7
bro ur 92 sohc use distributer
93dohc use coil hw u wanna make it hapen if u nt chnge wiring??
VTEC LoVeR
994
112
543
Kulim
by doing this, better you transplant a 4G91/92/93 DOHC N/A heart into your drive... 'kahwin' engine like your case might need experience 'pomen', setting must be good, some stuff must change and bla bla bla... something wrong, engine blown... JUST MY 2 CENTS...:biggrin:
luorenzo
21
7
503
sabah
but guys u see the engine 4g series is an engine family ? what else mod i need to done ? i jz plug and play the head and the extractor exhaust is it the same ? the ignition coil can i just use back my old distributor ?
mutanX
206
7
3,018
Sunway
not simple as u think..
Have input half bottle of tufoil into my 40 year old vw beetle engine because it uses only 2.5 Liters of 20—50wt engine oil.
Did it run smoother???
Don’t know! Because the original engine make so much noise anyway… hahahaa :o)
But more seriously…
The vw beetle aircool engine temperature used to be 220F and now, only 200F
A 20F degree drop – have to be tufoil, couldn’t be anything else because I didn’t anything else.
