Brittle Spark Plug Leads
stupidcar
5,000 RPM
Mar 18, 2013
5,567
850
Any foreman here can advice me?
My spark plug lead has gone brittle and those rubber pieces are in my spark plug chambers.
Tried to take some out but I can't.
I am gonna change my valve cover gasket soon but i still can't access it.
Letting the rubber dropping inside the combustion chamber would be my last resort. :bawling:
________________________________________________________________________________
Solution:
Now work Auto DIY mah!.....:biggrin:
Kaotim for bro. SC already. Need to break the pieces to smaller bits then attach water hose to vacuum hose and vacuum them out. No place for even chop stick to go it. Plug blocking the way....
As long as you don't take out the spark plugs I don't think you have an issue with the rubber dropping in. Just find thin chopsticks, tape some double sided tape to it and gently 'stick' them out.
You need new leads from the looks of it?
Yup, or plasticine, play dough, even my clay bar should be okay too.....:driver:
just the rubber..the lead will be fine anyway.....try use lidi or dawai wire...heck even u can use tweezer like this to reach
stupidcar
5,000 RPM
5,567
850
That one risky. Last the plasticine/play dough/clay drop in also. Suggest blutack
Luckily I didn't. I tried double sided tape. Its not strong enough.
Hmm, blutack seems good.
The thing is with the spark plugs intact, there are not much space. :bawling:
Wah, where to find tweezers? Need it to be long too. I was using a long Alan Key.
Double sided tape not strong enough? :confused: The pieces got oil? :smokin:
---------- Post added at 02:51 PM ---------- 6 hour anti-bump limit - Previous post was at 02:49 PM ----------
Have to custom make one. :s:
In that case get a fuel hose tape it to your regular vacuum hose then try suck them up....:driver:
stupidcar
5,000 RPM
5,567
850
The rubber is slippery, too smooth dy.
Will try the custom vacumm cleaner ltr haha
ixeo
4,788
3,080
KL, Malaysia
something sticky like blutack is a good try...
jeffayn
621
62
3,028
Klang
the spark plug lead is not design to last a lifetime... when is time to change you need to change.. or else it weakened the spark performnace and cause a lot more other problem than brittle plastic...
ken yeang
6,617
1,327
blue tack might not work......Try the sticky tar that use is to stick/trap rats.
Apply the tar at the end of long chopstick (the one used for frying yaucharkwai). then stick the pieces of rubber out.
sifus..which car works better with gsr turbo?
if possible..can u guys post a few engine set-ups?as in eg:metal gasket..cam pulley..bla bla bla..for engines? thanks
