Is a grounding cable/wire is needy for a car??
rawther
penang
is a grounding cable/wire is a needy for a car ?? do every car need to have it ??
does it have side effect ??
Does there any good grounding cable recommended to use on myvi yrv ??
or it just waste money..
is not something so improtant u need to use. its just better for ur grounding circulation. means a better charging for ur car in long run.. i guess..
If car is old then yes. It help to ground as old wiring tent to build up resistance....
I got a friend do own grounding and voltage stabilizers and alternator booster. All 1 package is much cheaper than what you get from those aftermarket branded groundings.
You can give it a try. He only use high quality materials and yet cost is cheaper than branded ones.
Talking of this, did you remove those from your BLM? Can transfer to Mira, mah.....:driver:
The orange grounding? That one giving to a friend. A friend want it for his FLX. At 1st thought of selling it along. :laugh:
no need to get so expensive, the fake HKS purple color will do, retail bout rm25 it helped me with my atos starting problem.
I got my fake HKS earth Grounding cable for RM90. Not the normal HKS grounding. Also in purple. :rofl:
Ya it helps as well. But those copper grounding isn't it better?
Bro. Danz get at RM25, you get fake at RM90.....:banghead::banghead: kena con again....:biggrin:
No no, last time got 2 types. 1 is HKS Grounding Cable. 1 is HKS Circle Earth Grounding Cables
This i got many years back.
http://www.mycarforum.com/uploads/sgcarstore/data/2/large/1_3.JPG
Danz one should be this one.
ya SF u are right......
my old supplier was selling it at rm9 but when I went there he closed down edi......
so the 2nd cheapest was rm20 but was quite far then opt for rm25, met the guy somewhere jaya IT Mall to COD>
Ya just remember u are in PJ as well, last week should have call u to come along to car mart haha!
RM9? SF mention RM90 woh!:hmmmm:
---------- Post added at 09:18 AM ---------- 6 hour anti-bump limit - Previous post was at 09:18 AM ----------
He weekend cannot lah! Family day..... Later on a few years you will be the same. Unker gone thru' in already......:biggrin:
