valve cover gasket still leak after replacing
Aug 24, 2013
2
I just replace my valve cover gasket and spark plug "o" ring due to leaking at the #4 cylinder spark plug. Few weeks later, i found out that my car does not have a good idle. I saw #4 cylinder spark plug is still leaking. Can anyone help me with this problem? What should i do and what cause the problem? Thank you!
4gbanger
1,958
386
1,683
Johor/ShahAlam
better spend abit more to assure our head is clear while driving rite bro vr2? but not all parts we can use original.. pocket koyak woo
Especially important parts needs original. Others at least chop shop, or recon. Cheap parts better not....:biggrin:
4gbanger
1,958
386
1,683
Johor/ShahAlam
i think cheap parts can still do.. non important parts maybe like gear knob, carpet, door visor etc... but still depends on the owner..
kayour
326
41
try to retighten the head cover bolt
sumtime its work
sometimes if you don't torque it right it'll still leak. And certain valve cover gaskets have a direction (up vs down). Incorrect install and it'll leak too. If plug 4 is being affected like that you might have a issue with the valve guide?
KenDiriwan
1,283
225
kendiriwan.multiply.com
I hope the engine sealant was not forgotten on the o-ring for 4th cylinder. It's like a grey toothpaste.
guys...need your help..i'm searching for a quickshift/shortshift
for my car,EG...where and how much...labour cost how much??
