can rx8 convert ngv ?
winsonchew
25
1,503
did u all owned a rx8 now?? or owned it before??
only the rx8 owner will understand what the hell of that guys thinking and feeling..
CSL, nice to see u here also.. LOLx..
can afford RX8 not means can afford the FC and the spare parts..
did u guys know how much a second hand rx8 now in the market?? around 65k to 75k can get one, manufacture years of course are 03/04/05 la.. BUT, years 2006/2007 higher a bit.. around 80k-90k
BELOW 100K only, it's not that hard to own one for people's..
did u guys know the rotary engine MUST pump RON97 all the way?? RON97 ain't cheap..!!
FC for my auto gearbox rx8 full tank about 55L x RM2.90/L = RM159.50, now drop till RM2.7/L i knew it.. only can run up to 280KM miles age only.. i never get to hit above 300KM miles ages before since i bought these car from FEB 2010 until now..
that's why i daily drive my W204 now, my rx8 just keep at home, my rx8, 1 month just drive 1-2 times only due to the FC high, all the way need to drink RON97.. not worth for me to use as a daily car..
if that guys only got 1 car, i think he say want to convert to NGV is not for no reason..
at the beginning, that guys should survey this car before bought it.. can join rx8clubmalaysia.com forum to ask the senior member opinion..
beside the FC, all the spare parts for rx8 are consider wear & tear item like steering rack rm5k, bubble spare tank rm1.2k, ignition coil rm1.6k, and many many more.. i already spent about RM25K for this rx8 is just for replace this and that genuine spare parts ONLY!!
only rx8-er will understand rx8-er..
thanks..
Waiora_ProTuner
619
221
thanks..
it can use ron 95...
winsonchew
25
1,503
RON95 can use, the car can run also after pump in RON95, but, it's strongly NOT recommended for RX8 this kind of ROTARY engine use.. YOUR CAR ENGINE WILL BE KNOCKING AND U CAN FELT IT..
want to rebuild engine or blow engine anytime?? can try to continue using RON95. but, it won't blow on the spot, it's take time, maybe 1 month, 6 month, 1 years or maybe longer?? No one can expect..
Japanese not recommended Rx8 this kind of ROTARY engine using the petrol LOWER than RON97.. MUST RON97 above, too bad, malaysia highest grade of petrol is just RON97 and the v-power racing NOT every shell station have it..
my experience that i filled in the ron95 in my rx8 before.. my O2 sensor failure after few days and engine knocking.. LOLx.. after i fill back RON97 then it's back to normal.. of course my O2 sensor has been replaced with a new one cost about RM800 only..
cRazYee
307
63
that's the luxury of getting sport car
if you can afford, keep it weekend.
pwhyze
924
356
1,563
thanks..
I'm sorry, but the points made here is ridiculous.
Power and high cost goes hand in hand. You want performance? You gotta pay big bucks for it. You want power in a rotary? Pay bigger bucks.
An RX8 as a daily? You're either gotta be rich or an idiot.
The only reason why someone would even consider converting an RX8 to NGV is because he likes the look of a sports car, but not the power behind one.
Personally,I call these people posers.
winsonchew
25
1,503
at the beginning he purchased this car, he think rx8 is just 1.3cc and it's very save fuel like myvi 1.3.. lolx..
my MONTHLY petrol are RM900-RM1100 when i use the Rx8 as daily car last time.. 1 month used at least 6 full tank of RON97, some other month maybe 7-8 tank if got go to outstation..
1 full tank lowest miles age is 240km for me if my foot heavy on the gas pedal.. normal driving highest miles age is 280++km for me.. i never get above 300km miles age before for 1 full tank of petrol..
the petrol that i spent on my Rx8 can use to installment for another car already.. LOLx..
jedi
108
4
3,018
hahaha.... sounds like I want to rear a tiger but meat is too expensive, can my tiger eat grass ?
ken yeang
6,617
1,327
I want to drive RE sports car........and mau NGV pulak.....
Anyway, the TS made a big mistake buying a car that he knows little.
Just like smartphone. Cheap to buy, expensive to maintain in the long run....So mau gaya? Mau murah? Mana mau?
Anyway, I oso curious if I can I drive RE sports car...can run diesel? Minyak masak cap buruh? Diesel? Recycled oil from frying french fried? Grease from frying bacon?:biggrin:
if piston engine can convert into ngv with proper tune with less power loss...
but rotary...n.a summore....if turbo rotary can offset back the power loss with turbo pressure
ken yeang
6,617
1,327
haiya....like that, just plonk in hayabusa engine.....compact, rev like mad.....powderful too :biggrin:
Hi Guys, would like to ask all expert advise regarding these 2 cars in terms of maintenance & car parts or any other comments can be given. I am looking to purchase either. Thanks.:adore:
