Ah Wah's New Workshop Location - Kinrara
Apr 4, 2008
2
Hello all. just bought na Airtrek. Is it recommended to bolt in turbo for my NA Airtrek? How much the cost + labour? hope to get reply.
stutzedward
3,416
561
Welcome to ZTH-MAC, bro.
Quite many years ago, someone did it. The result was not bad, similar to stock turbo power. But later, he wanted more out of it but NA engine has its limit, so he changed the engine entirely.
If u ask me, I reckon you to chg the engine. But bro, why not buy turbo version in the first place?
kaninbu
669
104
hey,bot is the 1st upgrade in ur trek.
na with bolt on turbo easily cost up to rm4-5k n boosting around 0.5bar.
last u 1 year after u get bored with low boost.
the nex upgrade is ur engine(real turbo engine) n gearbox(5 speed) n it cost around rm6-7k.
boosting 1.0bar-1.2bar
from time to time,u will get a full conversion of ur whole engine without investing so much in 1 time or if u got the money to spend,juz buy a halfcut rm13-14k n dump all in.
stutzedward
3,416
561
You so MISSING IN ACTION wor... and so is bro Avant.
hawhan
9
Going to take my evo 9 next Monday.. cannot wait anymore.
Guys, want to know when should I service the engine & turbo? that car is at 90k now.
Can Ah Wah rebuild engine & turbo also?
stutzedward
3,416
561
When u get the car, chg the following.
Timing belt
Engine oil
Gear oil
LSD oil
Brake fluid
Power steering fluid
Coolen
Plug
All rubber belts
Air filter
No need rebuilding if no problem la. Unless spoil only or u hv too much money to spare.
Racing6006
22
4
3,003
went to ah wah just now, nice guy, good service, my car feels and drives better now. going again for gearbox and some tuning setting by ah way.
hawhan
9
Timing belt
Engine oil
Gear oil
LSD oil
Brake fluid
Coolen
Plug
All rubber belts
Air filter
Thanks for your advice, have changed most of these except for the coolant. I will change a new radiator next month. The radiator water looks like teh ais now. :banghead:
---------- Post added at 02:04 PM ---------- 6 hour anti-bump limit - Previous post was at 02:03 PM ----------
oh...u r the owner of tat evo 9 at ah wah there ar?
Hi kaninbu.. yes the white evo 9. You are..?
evoFanz
Mar 10, 2013
13
hi all sifu... :)
need to ride on this thread....
beside ah wah can do maintenance service...
and i read tat they do 'upgrade'...
may i know what kind of 'upgrade' they can do?
eg:
upgrade / install of BOV from stock to other brand?
can do change Clutch?
stutzedward
3,416
561
hi all sifu... :)
eg:
Literally he does everyhing related to the Evos or Airtreks. From maintenance to light mods n hardcore 500hp monster. Depends how deep is yr pocket. What do u plan to do?
Even repair aircond and light bodywork.
DeaconFrost
284
159
Guys, is Ah Seng and his Burmese helpers the only workers in Ah Wah's workshop now?
I don't want to send my Trek to other shops, but I can see there's a real problem with workforce at Ah Wah's now.
kaninbu
669
104
small problem they still can rectify in a day.major problem take days.normal mah.
hey guys, after BOT for 2 months, problem arised again.
For your information waja have 2 ignition coil which connected to the spark plug. My car was having dificulty to start after long run in highway and get diagnosed that 1 side of the ignition coil malfunction. Today my car have the same problem again, and the foreman told me the same side of the ignition coil spoilt.
He suspect is the turbo causing the ignition coil malfunction. Anyone have any idea what is it going on? Could it be...
