OK This is how our Manual Transmission look like (in and out)
wah
120
6
Maybe later, now converting one of them from 4.17 to 3.823
sb3
1,141
14
5,138
Converting final drive to smaller ratio ? Does this compromise the pick up coz it will have longer legs on every gear change..
wah
120
6
Yup, a bit not much. b4 I bought the final drive did do some study, at first I plan to go with 3.611 but think I may over kill so in between is 3.82 and the different between 1 to 3 gear is around 1 to 2 km different in speedo meter so would cause huge impact on it. :)
D7zul
2,697
848
Shah Alam
the closer gear ratio, the faster it will finish a 400m drag race..
Gudluck :burnout:
wah
120
6
I didn't do drag race, I prefer save fuel. Thanks.
D7zul
2,697
848
Shah Alam
save fuel?
i'm not a technician or anything.. but from what i know, the lower the final drive will effect in the higher engine rpm at cruising speed
for example.. (this is not an actual figures.. just to show example)
4.17 final drive : 100km/h @ 3000rpm
3.82 final drive : 100km/h @ 3500rpm
so, how does it save fuel when u need to rev higher to get the same speed?
or.. am i wrong about this? :biggrin:
yeehau86
Feb 10, 2007
2,856
2,425
as what I know
Higher Final Drive: Faster acceleration, shorter gear shifting, lower top speed
Lower Final Drive: Slower acceleration, longer gear shifting, higher top speed
So yeah, I think D7zul is right.
wah
120
6
save fuel?
Thanks for your info, the actual should be another way round
3.82 final drive : 100km/h @ 2500rpm
So it will save fuel, btw make sure your car always in good running condition too...
If you go for drag race with 4.47 and VQ30, that will make a lot of smoke.
D7zul
2,697
848
Shah Alam
well.. i didn't see any reason to debate more on this
just get ur car running & update us :biggrin:
Gudluck :burnout:
wah
120
6
To All,
My gearbox project finally success!!
The main objective behind this project is our A32 2.0 M/T can't get good FC. Full tank 65litre maximum only can reach 770km, and I found my previous A/T can easily get 850km (maximum I did was 980km with 65litre), and the main cause for M/T is always the high gear ratio in 5th gear.
Few thing I need to share to who driving A32 M/T like me, you have few cheaper way to do the thing I did.
As you all know many Nissan car using the same gearbox (RS5F50A/C) and the best thing is RS5f50A/C have different final gear ratio 4.47, 4.17, 3.823 & 3.611
So far I know A32, A33 and U13 are all sharing the same gearbox RS5F50A/C
Option A (Cheapest for all M/T Driver)
1.) Get a U13 SR20 (bluebird aka altima) M/T gearbox
2.) Change the bell house, all the part inside are same
This may cost you less than RM2000 (gearbox + workmanship + part)
Estimate time spend: 2 week max.
Risk: If you lucky enough 3k rpm=120km/h, if not 115km/h, that's it
Reason: this u13 SR20 gearbox 1st and 2nd gear ratio is higher than our A32 M/T and the best thing is 5th gear ratio is lower than us, that's mean your A32 can get faster acceleration in first and second gear and yet better FC in 5th gear(115~120km/h compare with A32 105km/h in 3k rpm).
Option B (Expensive with risk but less headache and fast result)
1.) Go ebay get a year 1995~ 1999 Altima M/T (RS5F50 model) post + Tax estimate around RM3000~4500
2.) Same as first option change the Bell House
This will cost around RM6500 or higher
Estimate time spend: 1 month to finish the whole project
Risks: the gearbox may not pass through our beloved custom even we paid the tax, please don't ask why.
Reason: this Altima gearbox have the final gear ratio of 3.611, it will give better fuel consumption for our VQ2.5/3.0, from 4.47 drop to 3.611 with 5th gear ratio 0.740 you can easily get 135~140km/h in 3k rpm) Acceleration is slower but better FC
Option C (a bit of headache and expensive but a confirm result)
1.) Place your order to Courtesyparts USA for the final drive 3.823 or 3.611 (with post and tax charges around 2.5k)
2.) Place an order for a set of RS5F50 rebuild kits in ebay (with post and tax charges around 1k)
3.) Buy 2 gearbox A32 and U13 (around 2k)
4.) Work with your mechanic and get the thing done (priceless)
Estimate time spend: 1 month project, but i spend 2 years
Risk: so far no
Reason: Can get what you plan and most important is the knowledge and experience along the way.
To all who want to try this out, one thing you need to know is you need to give away some of your engine power and get a really good gearbox mechanic, especially who want to try the option B & C
Here are the gear ratio for A32, U13 and my "mix&match" gearbox
A32(VQ20) U13 (SR20) Mix&Match
Final drive 4.47 4.17/4.47 3.823
1st 3.28 3.40 3.40
2nd 1.85 1.95 1.95
3th 1.26 1.26 1.26
4th 0.954 0.954 0.954
5th 0.795 0.740 0.740
Est.Max Power Red Line
Gear Km/h per 1000 RPM Km/h @6000 RPM Km/h @6500 RPM
1 9.38 56 61
2 16.35 98 106
3 26.44 159 172
4 33.43 201 217
5 43.10 259 280
sb3
1,141
14
5,138
To All,
Risk: so far no
1st 3.28 3.40 3.40
2nd 1.85 1.95 1.95
3th 1.26 1.26 1.26
1 9.38 56 61
2 16.35 98 106
3 26.44 159 172
4 33.43 201 217
5 43.10 259 280
What about other components to get the gearbox working like clutch paddle, clutch pump, flywheel, gearshift ,clutch plate, etc? What are the compatible item which we can get from other cars? Sorry for asking as mt Cefiro is super rare in Malaysia. Thks.
---------- Post added at 06:35 AM ---------- 6 hour anti-bump limit - Previous post was at 05:54 AM ----------
To All,
Risk: so far no
1st 3.28 3.40 3.40
2nd 1.85 1.95 1.95
3th 1.26 1.26 1.26
1 9.38 56 61
2 16.35 98 106
3 26.44 159 172
4 33.43 201 217
5 43.10 259 280
wah
120
6
Sorry, I changed my clutch set 3 month ago, let me go back to hometown and check for you, I still keep the box.
wah
120
6
OK, here are some update after 3 day testing and tuning
1.) Surprisingly 1 to 4 gear are very powerful and 3.823 is far more better than 4.47. Engine noise reduce too
2.) It can "tarik" aka "long gas" until engine limiter kick in (6500 rpm) for 1 to 3. 4th before reaching 6000 rpm already 200km/h and 5th gear before reaching 5k rpm it is already 200km/h (P/S: I still keep the speed limiter on to keep myself alert the speed I'm driving on)
3.) 1st gear is 70km/h, 2nd is 105km/h 3th gear can reach 170km/h, and 4th gear speed limit kick in at 200km/h (1 to 3 gear switch at 6500 rpm, 4 to 5 gear switch at 5800+ rpm)
4.) 5th gear I decide to use back the 0.795 ratio rather than 0.740 because when gear change from 4 to 5, the rpm drop more than 2000 pm and slow on rev up, so my new 5th gear is 3k rpm is around 122km/h and is it much more better.
5.) I also lighten the flywheel about 4kg.
Actually it is very easy to find a M/T A32 or A33 halfcut, I spoted few along Jalan Kemuning and Jalan Kapar, and the price start from RM3500, if you decide to switch to MT the best way is buy a halfcut, it is far more cheaper than you buy all the clutch paddle, clutch pump, flywheel, gearshift and clutch plate separately. I keep one spare gearbox just in-case i over use my current gearbox and I still have 1 A32 and 1 U13 MT gearbox to let go.
You will be surprise that the clutch set is very easy to find.
sb3
1,141
14
5,138
Bro, can you take some vid on the car running on manual gears thks.
Just want to share some pictures of some Extreme Engine Mods....
All from Tom Yam Land....
