Mitsubishi GTO brake pads
l2s_turbo
1,068
154
Sorry mod if i post at the wrong place but i can't find where to post this question, I need help from you guys where can i find the brake pads for this 4 pot brake? Can anyone recommend me what brand and model? How much will it cost? Anyone know who has the stock for it? Please please please help... thank you.. :driver::banghead:
---------- Post added at 12:21 PM ---------- 6 hour anti-bump limit - Previous post was at 11:46 AM ----------
Thanks mod for moving it here.. any bros out there can recommend to me? Thanks.:adore:
zane_al
181
16
I thought many mechs would be able to source for them - cheap ones.
More expensive ones like EBC, you can try kakimotor.
For OEM, maybe you can order from these people ... 03 6258 3232 .
l2s_turbo
1,068
154
Thanks bro, but do you know what is the model no for the EBC brake pad? Many do not know.. unless i give them model number, else they need to dismantle my disc brake and take the brake pad out to search for.. as i'm in jb.. so kakimotor a bit too far i guess.. :banghead:
zane_al
181
16
I think you need to get a good manual (as in a book) for your car.
Short of that you can quote part # DP41097R (year 92-00) or DP41200R (90-92) . The risk is all yours.
To be 100% sure you need to dismantle them.
l2s_turbo
1,068
154
Ya thanks bro, i found also Endless CCA model EP264 is direct fit.. but got one mechanic quote me SSY EP230 can fit too.. EP230 used in Silvia,skyline,300ZX & WRX models..
AD_EG
6,328
231
Ipoh
bro can ask you...any brake squeak/sound when u use this brakes at low speed/slow braking?
l2s_turbo
1,068
154
It sounds ok to me.. just recently my brake pads going to worn off soon the squeak sounds came.. before that i din realise have these sounds..before i install it i already skimmed my disc and slotted it.. the calipers were all serviced before fitting into my car..
AD_EG
6,328
231
Ipoh
roger that bro... thanks !
manage to find the pads?
l2s_turbo
1,068
154
At last found back Project Mu b-spec pads in sg.. cost SGD260 include installation.. the model is F555 for GTO plug and play...
Click here for more info
Brake pad list for MITSUBISHI
AD_EG
6,328
231
Ipoh
alright bro..thanks alot...where in sg did u buy them? 260 including labour ? if pad alone?
l2s_turbo
1,068
154
Pad alone i not sure... but is best that let them install for you, at least hassle free.. anything can claim them ma.. i bought at SK Garage.. quite hard to locate them as they are in an industrial area.. but they are major doing VTEC cars.. saw many civic FD2R there.. and euro R too..
AD_EG
6,328
231
Ipoh
u tried finding in jb couldnt get any pads ah bro?
l2s_turbo
1,068
154
Jb hard to get.. kl maybe got la.. the closest is from Viswork offering me Endless NS 97 pads but is using nissan silvia 4 pot model ones.. slightly 3mm smaller than the original GTO's pad...
AD_EG
6,328
231
Ipoh
thanks bro...will try check out in kl how much the pads are going for.
if more or less same as sg price..ill just do in sg.thanks
hi guys...i would like to seeks some advise setting up 4wd system to my perdana evo.so can u guys share some info on:
1.which axle can i use for the project.
2.which gearbox is good(currently running on stock evo3 transmision lock to 2 wheel).do i need to change the gear box to evo 1 as i heard evo 1 gearbox is way better for "tarik jauh".
3.do i need to install a semi lock lsd for better traction?
4.is there any possibility after set up 4wd can ensorse in jpj(anyone can help me...
