Changing Stock Wheel recommendation
magnificolo
Jun 20, 2011
10
Hi all sifus..
I'm new to this section.. hv been thinking to upgrade my wheel from 15 to 16.. currently driving gen-2.. what are the things i should consider before making any purchase? Thanks in advance..
kumar22mostwanted
1,562
152
HELL!!!
i guess the only thing to consider would be the tire prices because i think a 16inch rim would be perfect for gen 2
15 inch is way to small
Hi all sifus..
Design, rims offset, tyres buy according to your priorities......wet, dry, handling, comfort, quiet etc....
magnificolo
10
yes, 16" did cross my mind..
how abt the weight? important? how to benchmark if the weight is suitable, light or too heavy?? I dunt hv heavy footie, thus usually go on steady drive only.. will all this affecting the consideration?
If not into racing or if car not under powered, then no need. They are more expensive also.
If want cheaper rims try RIM World, No:5, Jalan Perintis U1/52, Shah Alam. Have not been there for a while, hope they are still there....Old pictures
hello all sifu thanks for viewing this thread, i have the fog lights done and its working fine with my current setup, which is a direct +ve and -ve wire from batery to a fuse then to a swtich then to the fog lights, but im prety sure that this setup is not so safe in the long run, so i want to add a relay, my questions are
1. how to wire the relay, ? what number go to where
2. want to set it like this, pilot light onfog light on, head lights on fog lights can set on or off with swtich...
