Relay Wiring
bigkingzth
205
KAY AL
hello all sifu thanks for viewing this thread, i have the fog lights done and its working fine with my current setup, which is a direct +ve and -ve wire from batery to a fuse then to a swtich then to the fog lights, but im prety sure that this setup is not so safe in the long run, so i want to add a relay, my questions are
1. how to wire the relay, ? what number go to where
2. want to set it like this, pilot light onfog light on, head lights on fog lights can set on or off with swtich
3 master swtich to off fog lights but pilot light on head light on
hope can get feedback here
khguan
4,818
26
Seri Kembangan
fotopic.net
since ur wiring is direct from battery n using a switch.. u dun really need a relay..
jus make sure ur fuse is close to the battery (6") at the +ve wire of ur fog lights..
howiechoo
8,000 RPM
8,857
4
Bukit Jalil
and ur switch must be good..if use lousy switch, ur switch will melt or terbakar inside after sometime when u turn on/off the switch
bigkingzth
205
KAY AL
thanks for the help guys, i got it working, just want to ask if i wire wrongly will it still work i mean the relay, if wrong wiring it should not work one rite? is the voltage stable enuf to DIY a remote swtich?(ignition power)
trex92
756
5,018
for the relay, if it works, then u have wired it correctly. There are no + or - terminals for the relay so the wiring for a relay is not so complicated. It just acts like a switch.
wat do u mean by a remote switch (ignition power)? You mean to put a switch at ur ignition? If that is ur answer, yes, it can be done with no probs.
Hi All,
So finally i am working in a company with a blue and white chip logo which most of the people in the world know about this snobbish company.
After 'working' here for 3 months, i felt like this working environment stress me out a little bit..well not really a little bit, but a lot of stress.
Working here is actually never that stressful IF everyone:
- Never do a last minute job, tomorrow customer want to take the car,then why process the document 24 hours before. You can always do...
