Alignment problem on 4g93 mivec
mizi0604
179
6
Hi all sifus...
I need help from u guys,i'm facing an alignment problem with my car for quite a long time...My car tend to go right when i pushed the pedal even my steering was straight and it will go straight when i released the pedal...I've sent my car for alignment for many time and still not solve...I become headache while driving because my car going straight but i hold the steering a few degree to left..:stupid::stupid::stupid:
-Really appreciate if you guys can help me to solve this problem...:bawling:
risyia
168
30
3,028
Pandan Indah
If u have replaced only one of the CV joint, it may also cause this problem - car pulling to one side under acceleration.
It has something to do with the new 'tighter' CV joint transferring more torque to that particular wheel under acceleration.
mizi0604
179
6
suspect stabiliser bar bushes worn out...
tie rod end & lower arm could be the culprit as well.
Ok thanks...will ask my pomen to check all these things...
---------- Post added at 03:33 PM ---------- 6 hour anti-bump limit - Previous post was at 03:28 PM ----------
I haven't changed my CV joint yet...Might any other cause for this problem???
risyia
168
30
3,028
Pandan Indah
another possible reason are the tyres, had that problem once after changing to new tyres. The foreman had to swap left wheel with right wheel, also did not solve the problem. In the end had dismount it & refitted again in a 'swap' position, then only solve the problem. Maybe bunga punya pasal...
mizi0604
179
6
i just asked my pomen to check , he said maybe my suspension out for 1 side...
boyzone
2,669
5,148
How many Tyre shop u had been visited?
I had been face this issue on my mivec as well, at last, they manage to solve the problem via offset the rack. Hope can help.
Actually,my car is using yrv engine ..
The,problem is the speedometer works on gear 1,2 & 3 ..but not on D4 ..it didn't works ..sometime it will works if my car run more than 80km/h ... Is there some sensor,tcu or wire short problem ? ..
Please help me guys ..
