Satria fuel consumption problem
weikhee86
423
Hi all, I bought a Satria recently from my friend's cousin, who is a car enthusiast himself. Overall car is in great running condition save for a little problem I have noticed, which is the fuel consumption. The Satria 1.3 is supposed to be quite an economical car to run right? I drive to and from work everyday, working in Mid Valley staying in Petaling Jaya SS26. And I avoid the jams every morning by going out early but I have noticed that the fuel needle drops quite drastically even when I average 70 - 80km/h everyday. For your information the exhaust system is modified, piping is larger than stock, don't know the size but maybe around 2 inch or 1 3/4 inch in diameter? The exhaust muffler has also been changed to straight flow muffler. To add to that I notice the smell of petrol in the exhaust fumes. What could probably be the contributing factor to poor fuel consumption? Please advise.
baba838
Putrajaya
don't trust the petrol gauge needle...even my 8 mths old neo lite without modification faced the same situation. From full tank to half tank the needle will drop fast and than slowed down. What's important is to know for a full tank how many kilometers you can get.
ravingill
794
15
www.facebook.com
hey bro , i am a satria 1.3gli user myself , i belief ur car is a manual too, well first ur high fuel consumption is due to your exhaust setup , i have played with numerous mods for my exhaust and have finally settled for a 1.6 inch piping , straight flow center bullet and s-flow muffler. This setup now gives me nice sound (not too loud but has a grawl) and i get 250km for every RM50 of ron95 petrol added. That means i average 9.6 km per liter of fuel which is ok i feel , it was much worse with my earlier straight flow exhaust , i only used to get max 210km for Rm50 of fuel which is 8km per liter. I am a spirited driver by d way always giving the car some speed , and i usually drive at 120km/h -140km/h on daily basis. So my current setup has power for my driving and enough torque through out the rpm range. Straight flow setup only gives high end power which is usually after 3000 to 4000 rpm, before that car feels sluggish. I dont have that problem now as my power band has dropped , i get nice flow of power from as low as 2000rpm.
Another problem i can assume is engine condition , my car is currently at 160 000km and this are my results if yours is lower or higher it may vary depending on engine condition , also try and use semi synthetic oil for your engine , im using castrol magnatec 10w-40 and it keeps my car engine feeling light and responsive. I also added a drop in k&N air filter for better flow of air.
weikhee86
423
Hi there, thanks for your reply bro. I visited Kweng84's exhaust shop and did my exhaust as recommended by the sifu there, so I kept the 4-2-1 extractor swapped in by the previous owner, and redid my piping to 1.6 or 1.7 inch (I forgot but I just agreed to the recommendation) and used back the stock muffler. There is a drastic change in fuel consumption and pickup response after changing my exhaust system. Must say I am very satisfied with it now, more suitable for city driving since I am aiming for best fuel economy anyway so I can ignore the top speed performance for now. As for the motor oil, I have yet to service the car will do so when I have the time. I read somewhere that is it not necessary to use fully synthetic, semi synthetic is enough? Please correct me if I'm wrong, been using semi synthetic for my older car back in my hometown without any problem. Will fully synthetic oil be good for older engines? FYI I'm still running on 4g13 carburettor engine.
Fendy89
Jun 11, 2011
22
2
503
bro,i oso have 4g13 satria,i can get rm50 for almost 450km+ if not mistake..
use ron95 oso..
S16
64
508
im a satria 1.3GLI user, using MMC wiring... Just bought it 3 months back, changed few sensors including exhaust sensor and valve seal... Getting 300-330km for RM50 ron95 petrol... Fully standard... No mod at all...
damone
500
5
RM70 of 95 I will get around 480 km. With a few wild driving on the side. If economical driving can reach past 500 km.
david wai
Jan 14, 2011
19
503
shah alam
I am using 5w/30 for my 1,3 carb, no modification on everything at 390,000
km, use 500ml morey oil in engine n gear box with one morey's power booster
pick up,consumption,excellent like new,still don't require top overhaul as advise by my mechanic
Hi guys. I have a Honda City gm6 2014 v spec. Want to know 16mm or 19mm Ultra racing anti roll bar works better for my car as i feel the car floating during highway drive. My car is all stock and tyre is cc6. I am not a fast driver and I just want my car to be stable when I am on highway.
