![062c5943.jpg](http://i165.photobucket.com/albums/u41/jojo9984/062c5943.jpg)
Item(s):
Permanon Diamond Coating DIY Starter Pack
Package includes:
50ml Permanon Diamond Coat + 100ml Permanon Diamond 2 in 1 Revitalizer + 100ml Permanon Hecta PL+Spray Bottle
Kindly take note that all our products are 100% original from Permanon Germany and they are not localized or mix and match products
Price:
RM168 per set
Dealing method:
COD @ Bandar Utama or Courier via Skynet/Pos Laju
Location of seller:
Contact method/details:
Call/Msg/Whatsapp @ 012 565 8656
Picture:
![94f6fd72.jpg](http://i165.photobucket.com/albums/u41/jojo9984/94f6fd72.jpg)
Descriptions
What is Permanon?
Permanon is a leading-edge High-tech development in terms of surface-protection and cleaning on the basis of pure monomolecular silicium. Silicium, with the abbreviation SI14 in the periods system, is a natural product and is, after H2O, the most frequently occurring element on earth.
![Permanon.gif](http://i165.photobucket.com/albums/u41/jojo9984/Permanon.gif)
Silicium is found in sand, glass as well as in the human body. Even in the medical field, silicium in used in the research and development of new medicines. Permanon products with silicium do not undergo any chemical reaction with the material to be coated.Through a complex procedure, it was managed to create a static attractive force on all materials, without damaging the materials. Conventional waxes or silicone-oil combinations become unnecessary.
Permanon products are exclusively available as a high concentrate in trading units of 500ml, 1 litre, and 2 litre bottles and 5, 10, 20, 220, 1000 litres canisters.
These concentrates can be diluted with water with an applied concentration of 1% to 5%, depending on the type of surface (10-50ml concentrate on 1litre of water).The product Shampoo is a "Two in One" and contains cleaning and surfaces protectionThe product Supershine is a surface-protection with a higher shine effect. In the animation shown below, you see the "protection" with silicium.
The smooth surface is, under microscopic enlargement, a landscape out of mountains and seas, that fill itself with dirt and dust particles and/or water in the capillaries. Without surface-protection it is quite hard to clean these micro-layers; for this, usually caustic cleaners are required. With the use of Permanon-products you can act non-polluting, efficiently and simply, for Permanon-products with silicium do not undergo any chemical connection with the material to be coated on. A value conserving care guarantees you an optimum solution.
Summary of the natural protection characteristics of silicium:
- Temperature Resistant from -40ºC to + 300ºC
- Resistant against ultra violet (UV) light exposure- Resistant against acids/alkaline of pH 1-12
Advantages of Permanon
• Dirt cannot bond tightly to treated surfaces reducing incidence of mineralization or salt deposition and organic staining
• Surfaces are protected from environmental contaminants; extending in-service life cycle
• Non-toxic, no irritants, and biodegradable
• Reduces cleaning labor (time) by up to 50%
• Improves surface appearance for a longer period of time compared to traditional methods
• Reduces the need to use aggressive and potentially more hazardous cleaners
• Permanon products have a pleasant oder that does not require a masking scent
• Electro-static bond repels airborne dust; extending cleaning cycles for many surfaces
What is Hecta PL?
This is a optimized cleaning concentrate for removing of inorganic and organic soiling as well as fats, oils, protein, oil-containing soot, road tar etc. This product is indifferent to water hardness or alkaline levels. Permanon Hecta finds its use in car cleaning, engine cleaning, removes stains such as grease, oil, algae, tree sap, bird droppings, protein etc. Permanon Hecta can also be used as a lubricant when using a clay bar for great results.
Without using Hecta, your car body surface will not be clean enough, hence when you apply Permanon coating on it, it will not stick on the body for long.
What is Permanon Diamond 2 in 1 Revitalizer?
Permanon Diamond 2in1 Revitalizer is a hi-tech cleaning and protection concentrate for any non-porous (hard) exterior and interior surfaces. Durable semi-gloss finish based on pure monomolecular Silicium 14Si. Permanon Cleanzer 2in1 Revitalizer is ideal for cleaning painted and metallic surfaces, glass & synthetics. Washes and treats hard surfaces imparting a fresh Permanon finish. The highly resistant surface protection results in less dirt and grime adherence. Extremely effective for removal of insect and bird fouling.
Reviews of Waxson Car Care
Why Should You Buy from Us?
Waxson Car Care is the authorized wholesaler appointed by Permanon Germany GmbH and everything is 100% original products of Permanon.
As Advertised in Hypertune June 2012
![164cbf70.jpg](http://i165.photobucket.com/albums/u41/jojo9984/164cbf70.jpg)
![939c37f6.jpg](http://i165.photobucket.com/albums/u41/jojo9984/939c37f6.jpg)
![04c898fc.jpg](http://i165.photobucket.com/albums/u41/jojo9984/04c898fc.jpg)
![dc1b6f56.jpg](http://i165.photobucket.com/albums/u41/jojo9984/dc1b6f56.jpg)
![4e275a36.jpg](http://i165.photobucket.com/albums/u41/jojo9984/4e275a36.jpg)
![1cd83042.jpg](http://i165.photobucket.com/albums/u41/jojo9984/1cd83042.jpg)
For those who is not into DIY and would like Permanon Diamond Coating to be done by Waxson the professional way, you may click on the link below:
Permanon Diamond Coating by the Professional - Waxson
Like Us at Permanon Malaysia Facebook
