- Aug 9, 2006
- 389
- 0
- 1,516
Peerless HDS 6.5” Mid-Woofer (4-ohm)
- High Definition Sound(HDS) with Shorting Ring for low distortion,
- Rubber-Edged NOMEX (PPB) cone for very open & rich sound with High-End characteristic.
- Rigid Cast Aluminium Basket with an Aerodynamic profile.
- Poly vented underneath Dustcap.
- Special 4-ohm design for OEM series in Europe.
- Model: similar spec. as PPB-830874 (HDS series)
Specification:
*Power handling: 150 watts RMS/210 watts max
*Impedance: 4 ohms
*VCdia: 33 mm
*Le: 0.59 mH
*Re: 3.46 ohms
*Frequency response: 50-5,300 Hz
*Fs: 47 Hz
*SPL: 89 dB 1W/1m
*Vas: 0.70 cu. ft.
*Qms: 3.37
*Qes: 0.6
*Qts: 0.51
*Xmax: 5.5 mm
*Dimensions: A: 7.17", B: 5.71", C: 3.45".
Price: Sold OUT!
Contact: 012-9142998 (Lim)
