WTA DC2 intergra type r dashboard
freeman1314
203
4
I know this dashboard can fit into EG, but the lining at the side with the door would not match so good. Got quite a number of people swap dc2 dash and del sol dash into EG already. Try asking around and you should be able to find people who can do it. Not sure about the meter wiring though.
AD_EG
6,000 RPM
6,328
231
Ipoh
dc2 integra dash can fir in EG,need to modify.
wiring no problem.meter also no problem.
rattling sound wont be there if installed properly and add some sponges at the back at parts where its touching to avoid any funny sounds.
the side lining wont fit in 100% ...but it doesn't look awkward...got about 1cm gap...
door panel must modify a bit.
---------- Post added at 05:28 PM ---------- Previous post was at 05:27 PM ----------
Hi all toyotarians
im planning to get myself an open pod k&n air filter for my 4AFE (auto) engine. the problem is, there seems to have an air sensor attached to the original drop in air filter box. So, if i were to remove that air sensor, what will happen? will it affect the engine or more complicated things will happen?
Need advise and help
keong
