- Aug 14, 2006
- 66
- 1
- 1,508
Wira Handbrake light OFF even i have pull up my handbrake...
Do you guys know what is the problem?
Thanks.
Thanks.
it's a light bulb for the handbrake warning light in dashboard?Dismantle center console. See if the switch is connected to the handbrake. If it is, replace the handbrake light bulb.
Oh you mean your dash handbrake light not working. Look under the driver side fuse box and find the in-cabin fuse. See if that is burnt. Anything else not working? Like ceiling light or anything?it's a light bulb for the handbrake warning light in dashboard?
not sure is there a fuse for this...
just checked driver side fuse box and under hood fuse box... looks like no fuse for this ...Oh you mean your dash handbrake light not working. Look under the driver side fuse box and find the in-cabin fuse. See if that is burnt. Anything else not working? Like ceiling light or anything?
Wira using LED? Or u changed it?I further confirm by pressing level sensor of brake fluid... still no lights come out...
It is highly suspect the handbrake warning light kong... but wonder why LED can easily kong ... =.=
How old is your dash? Mine rosak after 8 years. Swapped everything out regardless of whether they spoilt or not.I further confirm by pressing level sensor of brake fluid... still no lights come out...
the meter console is not cheap ...How old is your dash? Mine rosak after 8 years. Swapped everything out regardless of whether they spoilt or not.
Those aren't LEDs, kinda like mini bulbs. I replaced the bulbs only! Not the whole meter
Yup, small mini bulbs behind.....Those aren't LEDs, kinda like mini bulbs. I replaced the bulbs only! Not the whole meter
