What is Turbo Lag and How to Identify & Overcome it?
jameswwt
Hi Sifu's:adore:,
can kindly share what is turbo lag and how to identify and Overcome it?
Thanks
turbo lag: the "time lag" between instant throttle input and reaching boost.
identifying it: when u press the accelerator, there is no instantaneous power.
overcome it: if dont want lag, use NA.
jameswwt,
here is some reference about turbo lag:
The time required to bring the turbo up to a speed where it can function effectively is called turbo lag. This is noticed as a hesitation in throttle response when coming off idle. This is symptomatic of the time taken for the exhaust system driving the turbine to come to high pressure and for the turbine rotor to overcome its rotational inertia and reach the speed necessary to supply boost pressure. The directly-driven compressor in a supercharger does not suffer this problem[citation needed]. (Centrifugal superchargers do not build boost at low RPMs like a positive displacement supercharger will). Conversely on light loads or at low RPM a turbocharger supplies less boost and the engine acts like a naturally aspirated engine.
Lag can be reduced by lowering the rotational inertia of the turbine, for example by using lighter parts to allow the spool-up to happen more quickly. Ceramic turbines are a big help in this direction. Unfortunately, their relative fragility limits the maximum boost they can supply. Another way to reduce lag is to change the aspect ratio of the turbine by reducing the diameter and increasing the gas-flow path-length. Increasing the upper-deck air pressure and improving the wastegate response helps but there are cost increases and reliability disadvantages that car manufacturers are not happy about. Lag is also reduced by using a foil bearing rather than a conventional oil bearing. This reduces friction and contributes to faster acceleration of the turbo's rotating assembly. Variable-nozzle turbochargers (discussed above) eliminate lag[citation needed].
Lag can be reduced with the use of multiple turbochargers. Another common method of equalizing turbo lag is to have the turbine wheel "clipped", or to reduce the surface area of the turbine wheel's rotating blades. By clipping a minute portion off the tip of each blade of the turbine wheel, less restriction is imposed upon the escaping exhaust gases. This imparts less impedance onto the flow of exhaust gases at low RPM, allowing the vehicle to retain more of its low-end torque, but also pushes the effective boost RPM to a slightly higher level. The amount of turbine wheel clipping is highly application-specific. Turbine clipping is measured and specified in degrees.
Lag is not to be confused with the boost threshold; however, many publications still make this basic mistake. The boost threshold of a turbo system describes the minimum engine RPM during full-throttle operation at which there is sufficient exhaust flow to the turbo to allow it to generate significant amounts of boost[citation needed]. Newer turbocharger and engine developments have caused boost thresholds to steadily decline to where day-to-day use feels perfectly natural. Putting your foot down at 1200 engine RPM and having no boost until 2000 engine RPM is an example of boost threshold and not lag. If lag was experienced in this situation, the RPM would either not start to rise for a short period of time after the throttle was increased, or increase slowly for a few seconds and then suddenly build up at a greater rate as the turbo become effective. However, the term lag is used erroneously for boost threshold by many manufacturers themselves.
Bump: Disadvantages of turbo
Lack of responsiveness if an incorrectly sized turbocharger is used. If a turbocharger that is too large is used it reduces throttle response as it builds up boost slowly otherwise known as "lag". However, doing this may result in more peak power.
Boost threshold. A turbocharger starts producing boost only above a certain rpm due to a lack of exhaust gas volume to overcome inertia of rest of the turbo propeller. This results in a rapid and nonlinear rise in torque, and will reduce the usable power band of the engine. The sudden surge of power could overwhelm the tires and result in loss of grip, which could lead to understeer/oversteer, depending on the drivetrain and suspension setup of the vehicle. Lag can be disadvantageous in racing, if throttle is applied in a turn, power may unexpectedly increase when the turbo spools up, which can cause excessive wheelspin.
Cost. Turbocharger parts are costly to add to naturally aspirated engines. Heavily modifying OEM turbocharger systems also require extensive upgrades that in most cases requires most (if not all) of the original components to be replaced.
Complexity. Further to cost, turbochargers require numerous additional systems if they are not to damage an engine. Even an engine under only light boost requires a system for properly routing (and sometimes cooling) the lubricating oil, turbo-specific exhaust manifold, application specific downpipe, boost regulation. In addition inter-cooled turbo engines require additional plumbing, while highly tuned turbocharged engines will require extensive upgrades to their lubrication, cooling, and breathing systems; while reinforcing internal engine and transmission parts.
turbos need to be tuned to “drivability” more than sheer horsepower. If you look at the turbo applications in the United States, fifteen years ago, they were basically highly souped-up, highly boosted, standard engines. If you take a different approach and used turbo-charging to increase the low-end of the engine, you’ll actually see better drivability from a two-liter engine than a three liter (non-turboed) engine: more torque, more low-end response, higher top end and better fuel consumption. American OEMs need to realize you don’t use turbos for horsepower alone, but to enhance the total driving experience.
You can make the engine 30 to 35 percent smaller, which takes all the weight away and you might use fewer cylinders and overall you have a lighter drive train.
Turbo Lag
turbo lag is your own definition
it not people definition
a simple question
Full boost 1 bar at 3800 RPM ..
do you consider it lag ?
A thread every 60 seconds
