jameswwt 1,000 RPM Senior Member Mar 7, 2008 1,127 78 1,648 Sep 17, 2009 #1 Hi Sifu's, actually what is the bore size for Evo 5 85mm Block in order to slot in 86mm 2JZ Piston?
F fct Known Member Senior Member Nov 15, 2003 211 2 3,018 kluang,jb,spore Sep 18, 2009 #2 if not wrong ,follow the piston ring size.not the piston size,piston size normally smaller 0.5mm than ring. the experience machining shop usually know what to do.
