bros,
during my initial setup on my safc2 ,i encountered setting like sensor type, car select etc (excluding the correction percentages - which i will leave it to dyno specialists)
well,correct me if i'm wrong...
1. Mivec runs on MAP sensor meaning pressure sensors
2. In car select , mivec is 4 cylinders and the voltage increases alongside the RPM
3. What are the pressure sensor numbers for mivec???
4. How come when i enter 4 cylinders, the RPM runs about 300 away from my cluster
According to Apexi manual, mivec is PR-5 ...However, when i enter sensor numbers as 5 IN / 5 OUT....i get weird idling problem...currently i'm using 6 IN/6 OUT which i dont get much problem...
Well, to those bros whom uses Safc2 in their 4g92 mivecs Gen 1....can you please help me out with this???
thanks ahead,
shawn
thanks ahead,
shawn
