hi guys,
is it possible to use a 2" exhaust piping for a 1600cc engine turbocharged for boost around 0.3~0.4bar
may I know why is it not advisable? based on normal practice or calculated CFM volume? I might learn something here.not advisable though. even Honda B16A 1.6 N/A go with 2.3" pipings.
if below 150 can use 2" piping, how much power can 2.5" support? any formulas to calculate that?regarding that boost level if engine hp still below 150hp then sure can use 2.0inch pipe...
but if more than that sure have to go bigger like 2.3inch and 2.5inch pipe
there's calculator to measure manifold length...but overall piping i don have...but that size is the rule of thumb that i found in website...if below 150 can use 2" piping, how much power can 2.5" support? any formulas to calculate that?
let's see. the engine is simply a glorified air pump, yes?may I know why is it not advisable? based on normal practice or calculated CFM volume? I might learn something here.
the boost seems low...BOT perhaps?
