Toyota Corolla AE92 headlight not working
soulfly
678
Miri
fakhrain.blogdrive.com
Car: Toyota Corolla AE92
Description of problem: Headlight is not working. When I switched on the headlights, the high beam indicator lights up, but there was no low beam. Corner light is working fine. Flicked the switch many times but the high beam indicator wont go off. At first I thought the switch stucked at high beam, but the high beam is working just fine.
Any idea? I've checked the fuses, all seems to look just fine.
Veloc
3,234
991
Sabah
Haha! Happen to me last 2 weeks! I send to check... Cheh... The relay wire at the battery disconnected. When that happens, the high beam switch actually on the low beams. Not high beams. Get it checked? :burnout:
DanzEterna
15,911
3,371
3,213
PJ
www.primeperdanaclub.com
my problem, my fog light lits up even when i switch off my ignition.......& all lights turned off.....
found out there was this red wire connected to + terminal, removed it & all settled.
soulfly
678
Miri
haish.... i couldn't find anything wrong (maybe i cant see the problem). i guess i'll have the car checked by mechanics lah.
UPDATE: Sent to car electrical shop. Some wire under the steering wheel compartment got burnt. Fixed already.
Hi,
i took my car to the garage as it was overheating and then stop the engine and then it wont start again until its cool down, but water not boiling but they said it could be down to engine temperature sensor which located on engine head.
just wondered if anybody got any ideas about this?
thanks
