Toyota 4age 16v wiring problem..
seaissky89
Aug 9, 2010
14
Ipoh
my engine cant start..there is no spark even before it reach coil..then it will start when i make a electric shock at efi main relay port after i remove the relay n put it back..there will be a sound like "crank shock"..then it will start normally..some one help me..i already go for 3-5 machanic..they dont know..
levin818
1,260
321
3,183
Shah Alam
1) how do you make "electric shock" at efi main relay? can you explain it in details?
2) can you pls explain "crank shock" sound more details... can't imagine it.
tks
559
28
3,028
USJ
+1
and just to share some experiences with similar problem before:
1) one wire @ ignition key loosened itself from the socket...dunno how..
2) igniter died...
Cheers
seaissky89
14
Ipoh
not at relay..but at hold that we put the main efi relay..there is a 4 hold..and then i take 1 wire n make a connection between two holes..then at the engine will be sound like "clink" in front of engine..when i put the relay back..i could start..if i said the ralay problem..i heve alredy change the relay..
---------- Post added at 10:23 PM ---------- 6 hour anti-bump limit - Previous post was at 10:21 PM ----------
2) igniter died...
igniter i have alredy change..n loose socket i check so far its ok..
my car satria will convert to 1.6 engine (SOHC),play play only,but wat kind of piping
exhaust system fit my ride? i only need is power in more pick up,middle power,fast to
soon in top speed,but make sure sound is quiet do not like blass!!
hope can help!:smile:
and others thing is where can find a rear brake disc system to my satria in low price??
