Depends on what aspect ratio of tyres being used.Rim 17" x 8jj....which width better should go...?
min 215 can ?
then how about max width ?
How about 225/45/R17 for my rim 8jj ?Depends on what aspect ratio of tyres being used.
If 215/45R17 then 8 " is max, as recommended is 7 to 8.
If 215/50 or 215/55R17 then 7.5 should be max, as recommended is 6 to 7.5
225/45 is perfect for 8' width.How about 225/45/R17 for my rim 8jj ?
Cox the halfcut rim tire is 245/45/R17 ...but the tire cant use
Some more makan minyak too if use 245.
Maybe oversize for his ride, that is why he uses 205.....A bit too small, better 215.
As bro. 6UE5t mentioned 225/45 is perfect for 8" rims, as recommended is from 7 to 8.5".How about 225/45/R17 for my rim 8jj ?
18" x 8.5J, you can fit from 225 right up to 255. It also depends on the aspect ratio (series) used.how about rim size 18" x 8.5jj, what is the most suitable tyre?
What is your ride original size?Hi vr2turbo. Thanks for ur reply...my rim is 18" x 8.5jj offset 32. Which size of tyre u think most suitable...235/40/18 or 245/40/18 or 245/35/18? or any recommendation?
225/45/R17 would be best for you.Now my car mark 2 jzx100
Front rim 6.5jj 205/55/R16
Behind rim 7.5jj 225/50/R16
I want upgrade to 4pcs rim 17" x 8jj offset 25 (all same offset)
And I planning upgrade toyota 4 pot front brake system
So want saiz tire should I choose ?
Yup, as bro. 6UE5t mentioned 225/45R17 almost same overall diameter as your current tyre size.Now my car mark 2 jzx100
Try checking out GT Radial Champiro HPY, 18" last I check below RM500....i use 215/45/17 for my front rims which is 8.25jj and for the rear i use 225/45/17 and those mothafak* is 9.75 inch wide.hahahahah.
cannot afford 245 as it would be too expensive.
but tire shop guys geleng2 kepala.kekekeke.
iam not with that stance or hellaflush nation.
But you're fitments reflect exactly hellaflush! :Pi use 215/45/17 for my front rims which is 8.25jj and for the rear i use 225/45/17 and those mothafak* is 9.75 inch wide.hahahahah.
