Timing belt
MAAN PV6
Nov 21, 2012
10
503
Hi V6 sifus
, im drivivg V6 year 2008, having noise around timing belt area, when i touch the timing belt cover can feel a kind of vibration, my car clocked 610981km, and is that because of timing belt or ??????
MAAN PV6
10
503
hi bro, thanks.. i planned to do a major service in another 10000km, and can i still run in tiz condition? and can i know y do tiz happen? and is it normal for v6? and if the pulley got problem how can i identify tat? need advise,thanks.
---------- Post added at 10:50 PM ---------- 6 hour anti-bump limit - Previous post was at 10:42 PM ----------
bro, since im new to v6, few questions to ask, plz recommend me
1) engine oil
2) gear oil
3) plug
4) timing belt
5) and my car sometimes the rpm is around 800 when ON aircond, what is the actual rpm?
thanks..
Hi V6 sifus
Since you are having this noise problem and will be having it checked out, why not do your major service at the same time. Even though timing belt have a service mileage like 70k or 80k km change, your car already 5 years old, so belt can also harden with time and especially heat....
DanzEterna
15,911
3,371
3,213
PJ
www.primeperdanaclub.com
bro, must get your figures right, mileage 610981km / service in another 10000km...for me its more than 2 years more to go.
u need to open the timing belt cover & run your engine again...
check where is it wobbling.
800rpm when engine is on with aircond is normal.
ronaldindin
207
29
528
www.12bet.com
is it true that old timing belt need to replace every few years? mine is giving some weird sound lately, this is because of it's not lubricate enough?
If it is a timing BELT, there is no lubrication as it is made of rubber and any oil on it will degrade it faster. Timing belt you can change and gauge by mileage if you travel a lot (follow the recommended mileage) and if low user, better to change by period say 5 years as the rubber can harden and snap....
my v6tt timing belt change due...already 6th year........saving up $$$ now.....scared it will snap.
I kena before in 3rd Generation Accord. Bought 2nd hand 4 years old, very good condition, SC maintained, Doctor's Car never used for outstation, that in why 4 years only 40k km on odometer. Mechanic recommend timing belt change at 60k km, so happily use first, then at around 50k km and 5 years old it snap while outstation. Funny thing is driving at 60kmh in kampung road....Lucky in a way driving slow so only damage was the belt, nothing else, but had to spend extra night outstation....:rolleyes:
MAAN PV6
10
503
hi sifus,
yesterday i went workshop, and the formen checked and showed me that my timing belt is not tight enough and my tension-er got prob, and i already bought the timing belt kit and water pump, and there got two tension-er bearings 5seals, and now i don't understand about the timing belt tension-er :confused: ,and is tat i need to change it to new whenever do major service? is that i need to buy it separately?
Echoing Tom’s recent entries on the forums, let me share my latest trip to Thailand where I got the privilege to be among the first few in the region to drive the new Subaru Forester and witnessing the launch at the 2016 Bangkok Motor Show...
