tight handbrake after cleanning dust
likeme88
23
1,503
last week when i sent my car to change tires, and i also told the mechanic to clean away the dust in the drums...but recently, my handbrake was so tight where 1 or 2 clicks will prevent the car from rolling if i engage D mode..previously when i engage D mode, the car will move abit... so, when i try to remove the brake drum cover, it was so tight and eventually removal was successful, but fitting it back was super hard, the cover blocked by the brake shoe...hmm..not to mention, left drum brake is much hotter than right ones...wonder what is the problem..is it normal after cleaning??:hmmmm:
corona_ice
821
49
sunway city
hummm drum brakes.... it's just the case of ur mechanic tightening it to much.... there's like a adjustable screw near the brake shoe... he needs to re-do it man... nothing serious... while he's at it, ask him to check the cable also....:nurse:
likeme88
23
1,503
hmm..but this morning i tried to open the drum cover, it was so hard...and after i had remove,then fitting in back was hard where the drum shoes are blocking/touching the drum cover from entering nicely.....so just need to adjust the drum shoe??:confused:
corona_ice
821
49
sunway city
yup! thers's like a round flower like screw, use a flat head screwdriver and turn to release or tighten the cable....
hi all,
on most tri y headers, i noticed pairing of cylinder 1 and 4, 2 and 3 (1-4, 2-3) which forms non-sequential header but i saw some tri y headers have pairings of 1-2, 3-4 which forms sequential header
im hunting for new tri y header but im confused with which one to choose to suit overall street performance output
anyone can enlighten me on the effect of pairings of header primaries on the power curve?
it will be good if i know the difference so i can choose which one is...
