throttle body
sharp_detektif
sharp_detektif
20
HI TO ALL....
here i have one question. hope anybody can help me. actually my car is wira 1.3 but my throttle body already rosak.
so now i plan to use either perdana or putra throttle body. so which one is better and whats the different if i change from throttle body 1.3 to 1.8...
really need help. i know all u guys out there very familiar with these kind of things. so please pm me.
thanks
simon
simon
292
mine is wira 1.5 & my throttle body also gt problem but im not sure if rosak or not......hw did you conclude tht yr TB is rosak ...like what are th symptoms?? i may also want to chng to bigger TB in future...but will there be any gain in power??
mag9556
mag9556
2,770
43
1,648
More Power = More Fuel..
Somemore if change just the TB only there will be a bit different only.. anyway..Good Luck..
TB spoil...
Idling sometimes ok, sometime crazy..
The TB gear kong liao also coz a lot of problem whn aircond comp is working..
Drive in the h'way suddently engine off by itself..
A lot of ways..above matter is just a bit only..
sicness80
sicness80
70
got fren change perdana TB,said power abit,but also got foreman said dun have any effect,cos duunu which part inlet is small,i not sure wat he say,but more big TB more fuel u spend..tis is true.
boyzone
boyzone
2,669
38
change TB u need to bore ur inlet manifold as well to matching.
But only upgrade this item u will not feel much different as u still need to go to fuel mapping and ignition set up.
4g91ajer
4g91ajer
188
I thou 1.3 kenot use 1.6 and above throttle body becoz air fuel sensor is not the same....Can arr??
alexlimbk
alexlimbk
87
Piece Of My Experience, Currently Using V6 Tb But I Change The Intake Manifold Oso. Immediate Effect U Can Feel, Very Light On Ur Oil Pedal, Press A Bit Only Can Run.
About Fuel Consumption, Mine Ever Get Better Coz Dun Need Press Hard On Oil Pedal Anymore.
Depends On Ur Modd & Mech, Make Sure Mech Set Correctly.
pifecto14
pifecto14
348
PJ
Oh god...I'm having the same prob...car mati engine when slow down. But that occurs once a while oni. But the idling goes down till 0.3k rpm then goes back up to around 1k rpm whenever i let go of the accelerator and free the gear. :confused_smile:
Alexlimbk: Where you got your throttle body and what intake manifold u changed?? Got contact?? Thanks..
