if your aircond is on when that happens, check the vacuum pipe. i dunno about yours but when my car last time got this prob, its because the vacuum compensation thing when aircond is on is not set properly. so the engine do not have enough power to keep itself running when pulling the compresor when idle/no throttle.najibkl said:Whenever i dropped my gear, suddenly engine turn off? Needs to chg my gearbox? or any others else possibility?
ryan05 said:What if i facing difficulty when i wanna engage 1st gear .......... feels like very hard to push it through with somekind of cracking sound.... is there something wrong with this........ ?!
check your clutch's hydrawlic system, if it is using one. mine just face that prob a week ago, 6 hours later my clutch kong, cannot shift at all.ryan05 said:What if i facing difficulty when i wanna engage 1st gear .......... feels like very hard to push it through with somekind of cracking sound.... is there something wrong with this........ ?!
rollakid said:check your clutch's hydrawlic system, if it is using one. mine just face that prob a week ago, 6 hours later my clutch kong, cannot shift at all.
your situation is same as mine when it just started to feel wierd, basically if not mistaken, its like with the clutch fully depress it still can't pull the clutch up enough to release it. thats why it is hard to shift in and a cranking sound when you do. at least thats my prob, with similar situation.
Similar threads | |
