Fuel Pressure Regulator, right or wrong install?
bo093
Jul 6, 2011
37
5
508
Hello ZTH sifu,
Need help about FRP
My brother recently swap to another turbo on his L2S.
During the conversion, install a FRP and Fuel pump (Supra pump).
The weird thing is, the FRP is not install at the old FRP on the fuel rail.
If install at the usual place, the fuel filter will shake. (The turbo installer said that)
If I'm not mistaken, right now is
Pump > Filter > FRP > T joint
At the T join, one go to fuel rail, the other go to tank.
When to do a top overhaul at another tuner.
The tuner said, there should not be a T joint.
But He also said, 'it might work because, once the fuel rail is pressured, it will go back to tank via T joint.
But now, for me. I think like this.
Adjustable FRP is meant to keep the fuel rail pressurize at your desired settings.
If the FRP is before the fuel rail, how does it keep it pressurize?
Will it still work? :confused:
Opinions would be helpful. My brother thinking of moving where it should be, after I said all the mambo jumbo engineering things I learnt in class. :rofl:
^pomen_GTR^
7,000 RPM
7,509
1,690
The Mines
it should be:: Pump>>Filter>>Rail>>Regulator>>Tank..
because we want the rail pressure stable at all time...
if configuration Pump>>Filter>>Regulator-T-Rail/Tank then fuel starving might happens in the rail because not enough pressure coming into rail (wasted into return tank) :adore:
my 0.0000000001sen
bo093
37
5
508
After reading my notes for my exam tomorrow. (Automotive Student)
Is fuel system. HEHE.
Somehow, the slides contain a few setup of fuel system. And it wasn't included in the lectures.
Because 150+ slides gonna be too details.
The standard loop, Tank>>Pump>>Filter>>Rail>>FPR>>return to tank
I think the turbo installer using this style.
Same concept. I guess. :banghead:
Not sure why the turbo installer did it that way.
I prefer the standard way, because almost all car are like that.
Less headache when other tuners see...
Oh well, you can't blame not doing it right if it works okay?
Like they say, tak suka, buat sendiri. :rofl:
Watch out this amazing advertisement that highlights the driving fun of a Beetle, amongst other living creatures living in the jungle itself. Looking forward to the new 200hp turbocharged 2012 VW Beetle!
YouTube - Volkswagen Commercial: Updated Black Beetle with the 2012 Beetle
