Strange overheating problem
cvkit17
2,884
1,354
Yea...the only part that affect the performance of two different system is the fan. I can't think of any other possibilities already...compressor problem doesn't affect the radiator system. Water pump problem doesn't affect the air cond system. If you're getting these two problem at the same time, means a common part for these two systems got problem. If not, lagi headache coz you might be getting problem in each of the system, separately.
ixeo
4,788
3,080
KL, Malaysia
Work from cheap to expensive solution. Change the radiator cap first, it could very well be the culprit. The usual suspect is really the fan motor for a Myvi.
EDIT: if you think its strange, you haven't see my overheating problem. lol.
30,002
Wah! yours from twilight zone?.....hahahahahaha:rofl:
ixeo
4,788
3,080
KL, Malaysia
ixeo overheat cos watch too much XXX. nothing strange there :rofl:
never overheat d la.. now use fully synthetic lubricant.
15,390
*Shakes head at arturo and ixeo* :canabis::rofl:
Anyway - update for my situation is I've changed the radiator cap. The old one seems a bit tight to compress and it wasn't smooth toe compress. Kinda felt a bit rusty on the inside.
Will have to monitor for now. These days it hasn't been hot enough to affect the car yet.
arturo
nooB
2,722
1,083
SateCelupLand
ask ixeo recommend the XXX he watch when he experienced strange overheating...it should get yr myvi overheating in no time...
option1978
213
83
My colleague faced similar problem with her 1 year old Viva recently.
A/C cold when temperature is low (when starting car) & hot when temperature rises & idling.
She sent her car to Perodua & they immediately detained her car after checking for the problem but she wasn't able to explain what is the problem detected (lady mah) but only recalled that Perodua personnel told her that her car will catch fire if she insist on driving it before they repair the problem.
Will ask if she still keeps the receipt for repair, if so will post what is the problem that they detected. Was supposed to claim for warranty but need to wait over 2 weeks to claim & she ended up paying for the repair (cost her around Rm 100.00) & it solves her problem.
ixeo
4,788
3,080
KL, Malaysia
Did you get this?
New Bling: D-Sport 1.3 Bar Radiator Cap
15,390
Catch fire? I don't know how my car would catch fire but whatever she did for RM100, please do let me know. I've spent RM10 on a radiator cap, RM25 on a thermostat, RM25 for coolant and a lot of time spent troubleshooting!
RM80 for a rad cap? No thanks. I don't really agree with using a higher pressure cap. Increase the boiling point yes but that basically means you have hotter coolant running through the system. How's that a good thing for jam situations? If racing / track, that's a different thing.
30,002
Higher pressure also, make sure the system is okay. If not, may get leaks and probably even burst hoses....
Maxx
2,072
42
PD-Putrajaya-KL
www.zerotohundred.com
head gasket ok?
open rad cap, let the engine warm-up.
after fully warm-up, see got bubbles or not at the filler mouth.
15,390
head gasket ok?
No visible leaks from the head. No bubbles (big ones.. small ones from the heat got la)[
The weather hasn't really been hot enough to really try this but I've been stuck in a few jams lately and so far so good. Seems it might just be the rad cap since the old one was kinda rickety and rusty.
15,390
Latest update :
With the recent heat wave I've had the chance to test the car idling on a hot day and stuck in traffic in hot weather... problem solved!
A simple radiator cap change. Dang!
ixeo
4,788
3,080
KL, Malaysia
You should be thankful, not Dang!
If it DIDN'T solve the problem, you're fucked cause it can be a million other reasons.
15,390
The "Dang" was more of a "Goddammit.. such a simple thing like this and I didn't find it earlier" dang.
:biggrin:
So i was talking to this friend of mine .. and he mentiond some things that got me wondering ..
a) Lowering the car means more downforce .. this means the car is being pressed harder on the road .. and will lead to more wear on the tyres ?
b) By lowering your car, the chasis is more prone to feeling the impat of every nook and cranny on the road .. reducing its stiffness ..
so .. since iam considering lowering ma ride .. Wira SE .. whoese suspension has to be said is one of the...
