Some Questions about Lowering your car
yeehau86
Feb 10, 2007
2,856
2,425
dear all ZTH members,
I want to lower my car, but still considering 3 options that are available:
1) Chop current stock springs
2) Buy Sport Springs and Sport Absorbers
3) Buy Sport Springs only
which of the 3 options should I choose? some say option 3 is enuf, some say must choose option 2...:confused:
csl
1,285
498
1,683
Malysia
What car you are using? Not every car has the same solution. But in generally, I reckon you should not waste any money on this. Save the money and get a set of adjustable low/high and hard/soft coil over. Maybe can buy a recond set with cheap price from halfcut shop.
tofu_manic
1,342
91
5,148
option 1 is definitely out, option 3 as well...best u get a set of springs with a matching set of absorbers, so u noe they will ngam each other...less trial and error needed...
or u can try what CSL has mentioned earlier, depends on ur luck tho...
meltan7
619
32
Kelana Jaya
don't ever chop your springs, either stock or sport springs. if you're on a tight budget, you can go for option 2, but in the long run, your absorbers will wear out over time. best is, save the cash, and get yourself a set of adjustables.
ixeo
4,788
3,080
KL, Malaysia
helps if you let us know what car you have. option 1 is definately out. option 2 is good enough for normal driving.. e.g. G|A|B SA absorbers + G|A|B sport springs. its not adjustable but it was designed to function together while lowering your ride.
adjustable coilovers would be the best option, but it does cost significantly more.
yeehau86
2,856
2,425
i am driving Wira Aeroback Special Edition 1.5
arrowhead
4,621
152
5,163
Damansara/PJ
it also depends on what ur car is used for? daily driving? i mention this because, most hi/low adjustables are too stiff and bumpy for daily driving. unless u go for hi/low soft/hard, which cost alot more... however i can't confirm this as i havent tested a hi/low soft/hard adjustables before. so choose wisely
yeehau86
2,856
2,425
i have a friend using adjustable..sit at the back damn bumpy until my eyeballs wan to drop...sigh
boyzone
2,669
38
5,148
since u are running with 1.5 SE, u have an option go with sport spring only.
with 1 inch lower would not damage ur absorbar.
Before I go to coilover, sport spring with stock absorbar was service me near 6 yrs. :biggrin:
Now plan to let go my Germany sport spring, just PM me If u interest. Thanks.
yeehau86
2,856
2,425
u mean sport springs with stock absorber u used for 6 years no problem?
boyzone
2,669
38
5,148
yup...run for 6 yrs .. no problem.
the spring still with me... Interest? will let go cheap. :biggrin:
Hi guys, been a while since ive posted something.
So here's d prob, my car is starting to give out sounds during cornering as well as on the straights.
As for the cornering sound, im sure its the driveshaft. So i hope i could get a picture of the price including labour on that part.
As for the straightaways, any ideas? Im getting realy2 scared to drive now and Its a week before payday. T_T
edit: sent for repairs. 280 for driveshaft right side. used wira 1.5/1.6 punya...
