Side Gapping Spark Plugs
babahni
babahni
13
ipoh
Dear friends,
Here is another article about side gapping spark plug ,
I quote the article :
First, obtain a high quality over the counter version that carries an economical price. Motorcraft and Autolite come to mind for their performance and safety features of inherently melting before the piston does. Then carefully shorten the electrode arm by taking a die grinder with a small cut-off wheel and remove a small portion from the end. *Do not* nick any part of the center electrode or porcelain! As seen in the photos below, nearly the entire center electrode can be seen from the bottom of the plug as compared to the standard version being completely shrouded from view. This modification will expose more of the generated spark to the combustion chamber, thereby more completely igniting the air/fuel charge instead of the spark being forced to propagate in a sideways direction and not directly into the majority of the combustion mix. This procedure of exposing the electrode is called "Side Gapping", and has been a well kept secret for many years in the racing circles. While some may debate the amount of Horsepower, Torque & Fuel economy increases, there is no disputing that side gapped plugs significantly improve spark propagation as well as reduce plug fouling and loading up, with no sacrifice to your wallet.
NOTE: Side Gapping spark plugs has been the serious racer's secret since the early 60's. Only recently have major manufactures started producing this style of plug for mass production, but with unreproducible sophisticated designs, since if their expensive plugs looked like these, they would lose all their business to home mechanics copying that simple to do at home design. Experiment with different configurations and… Have fun!
http://performanceunlimited.com/illustrations/sparkplugs.html
http://performanceunlimited.com/documents/plugsidegapping.html
jaywat
jaywat
1,329
same like previous side gapping sp post?? done long time ago le
