After market RSM will not be able to remove the speed cut for our Airtreks. You need to remap your ECU to remove it. So do it together during ECU tuning.
Actually, it;s not removing. The tuner will just shift the 185kph speed limit set in your ECU to 400kph. So theorically you can't reach 400kph, hence speed cut removed.
Honestly, how often we drive above 185kph? I think it's pretty rare, hence for me, I did not make it a priority to do it.
I understand that your exhaust is still stock based on the mod list you mentioned. If I am you, the next thing to do is to get a full exhaust upgrade. Straight flow without cat, it may sounded a bit loud, just put 2 mid-box to muffle the sound a bit. The free flow exhaust system will instantly give you very good response and the laggy feel above 5000rpm will be freed! Coupe with your Evo 7 cams, it will work like wonders.... :)
