Sharing about my car purchase- Iriz 1.3 MT MC2, suggestion needed on mods :)
Ceejay3196
37
8
27
Yes, change the tyres and learn the characteristics of the car first.
Agree to getting a better tint especially with better total solar heat rejection and not some other variables which the sellers market them to you. Apparently, the air cond robs the engine of its power quite a fair bit.
Also, if you want to remap your car, I can share the details with you.
Hello, thanks for your reply too! Of course I would like to know the details of remapping my car, as I am quite curious how would it effect FC when not going to bonkers mode.
When bonkers mode activated, to hell with FC lah adui.
Ceejay3196
37
8
27
New car, why change all that la. Just use it first for a few years and warranty over then start thinking mods.
That is my plan. Just that can't help but being itchy and began my cari pasal life on doing 'homeworks"
DNGFashion
95
14
508
Rims and Tyres is to make the car look better, but lowered spring, in all honesty i can't find fault on my car suspension when it come to stability and corner support. But surely it will make the car look way better lah.
For samco and brake pads, those are only 'gatal' choice. please enlighten me more should you find my understanding wrong.
You will know the fault of the suspension soon. Well at least, for me (1st gen of Iriz), it was not stroke with adequate length and proper loading, you will feel the bounciness (Izso mentioned about this on another post). Adding to that, the suspension didn't last until 50k km
It was done by Y3 Ecu Tuning. I remapped it for the ease of purely city driving and faster CVT lockup. A reduction of approximately 0.3L / 100km was observed.
Since you like the suspension, make the car handle better with better tyres and lightweight rims. That'll make a huge difference in performance. Like a stock Myvi rim + tyre 14" (175/55/14) is as light as a 15" lightweight Advanti rim with PS4 tyres (195/50/15) but the 15" has sooooo much more grip.
As for eibachs, the lowered spring means the "compression" is a lot less than normal length springs which will make the ride a lot harsher. Eibachs aren't hard springs either so the absorbers (long stroke) won't be able to extend and compress normally. You'll ruin the handling.
i have a screw on type gear knob(hope u all know what i mean, heh heh)...
due to constant gear shifting, the gear knob will loosen after some time which i have to rescrew it back(very annoying)..
recently i found out there's holes on my gear rod due to the stupid screws...
is there anyway to make it as tight as those stock gear knob n not damaging the rod? and save up the work of screwing back?
thnk uuuuu
