![2008rufctr3rearsection1pc1.jpg](http://img396.imageshack.us/img396/8898/2008rufctr3rearsection1pc1.jpg)
RUF is famous for making Porsche's, which are already as sharp when they come from the factory, into Double-edged samurai swords.
They have now come with a Porsche based supercar, with figures that can match any Ferrari, Lamborghini or even the Pagani's.
Powered by a 700 hp twin turbocharged Porsche six, the new CTR 3 has a top speed of 235 mph and a 0-62 mph time of 3.2 seconds
RUF Press Release
Technical Data
Body
Body build in steel, aluminium and kevlar-carbon. Rollover protection in A-pillar and in birdcage. The birdcage forms a torsion resistant unit with the front chassis by joining to the sill beam and the A pillar.
Front structure steel, zinc dipped
Safety passenger compartment steel, zinc dipped
Engine and transmission frame space frame and birdcage
Front bonnet and doors aluminium
Body shell Kevlar-Carbon composite
Engine
Type turbocharged boxer
Cylinders 6
Displacement 3,746 cc / 228.6 in3
Bore 102 mm / 4.01 in
Stroke 76.4 mm / 3.01 in
Output 515 kW (700 hp) at 7,000 rpm
Max. torque 890 Nm / 656.5 lb-ft
Compression ratio 9.2 : 1
Engine control unit Bosch Motronic with OBD-2
Turbo charger two KKK turbo chargers
Intercooler two air-air-intercoolers
Transmission
Power delivery rear wheel drive
Transmission sequential 6-speed-manual transmission,
transversal, angle drive, shift indicator in the instrument panel
Limited slip differential multi-disc locking differential
Locking value load / deceleration 40 % / 60 %
Chassis
Front axle McPherson struts, anti-roll bar
Rear axle multilink rear axle, anti-roll bar
horizontal coil over shock absorbers
Steering Power assisted rack and pinion
Brakes
Brake callipers front/rear 6 piston fixed light alloy callipers
Brake discs front/rear ventilated and cross drilled
ceramic composite discs
Brake disc diameter front/rear 380 mm / 15 in / 380 mm / 15 in
Anti-lock braking system Bosch ABS 8.0
Wheels and tyres
Wheels front/rear 8.5 x 19 / 12.5 x 20
Tyres front/ rear 255/35 ZR 19 / 335/30 ZR 20
Size and weights
Length 4,445 mm / 175.0 in
Width 1,944 mm / 76.5 in
Height 1,200 mm / 47.2 in
Wheelbase 2,625 mm / 103.3 in
Front track 1,506 mm / 59.3 in
Rear track 1,585 mm / 62.4 in
Empty weight with 6 speed manual transmission
According to DIN 1,400 kg / 3,086.4 lbs
According to EG-standards 1,475 kg / 3,251.8 lbs
Performance
Top speed 375 kph / 235 mph
0-100 kph / 0 62 mph 3.2 sec
Price
Euro 380,000.00 (plus VAT)
Since its a supercar, it even costs a bomb...with a mind blowing
0-100 Km/h acceleration of just 3.2 seconds..it should out run the Mclaren SLR, the Pagani zonda.the Lambo LP640..and the Ferrari's atleast on paper...
![2008rufctr3sideangle128et4.jpg](http://img396.imageshack.us/img396/3395/2008rufctr3sideangle128et4.jpg)
