REAR DISC BRAKE...
rayracer
7,133
11
CHERAS,TMN CONNAUGHT
NIL
HALO! guys! need a help!
i wan to change rear drum to brake disc,so wat size or car disc brake
can use in satria 1.3, did it need to change 15inch rim? :)
-ArChAng3L-
2,777
11
5,138
then your rear discs will be larger than your front discs
which isn't too good ;)
and minimum rim size for rear discs is 14" if i'm correct.
NukeeZoid
2,330
176
further_seems_forever.blogspot.com
Originally posted by najibkl@Mar 15 2005, 10:57
Can't simply chg meh?
Agreed with -ArChAng3L-. Better chg full set disc break. Much balance and stable.
where can simply change one...if the rear is bigger than the front then the braking isnt balanced....if you want to...go get a full set of GSR brakes...
or get the same size as ur front disc brakes...
the 1.6 rear disk brakes should work fine for 1.3 i think....
and yes 14 inch rims is a must...
Hi all,
My friend's silver FD2 was stolen last weekend in Subang Jaya. They broke open his gate to steal the car. On top of that, they also stole his dog. :banghead::banghead::banghead:
Please look out for a Silver Honda Civic (2.0) with the number plate BEA 1881.
Thanks
