Proton Wira Alarm Problem
sifuconman
25
503
Hi
I have a problem with my Proton Wira.
If I switch the room light to "Door" the room light will remain on even if I closed all the doors and the alarm will trigger immediatlely after the alarm is set.
The alarm works perfectly if I switch the room light to either "On" or "Off".
I had checked all the door switches and they are all working. I suspect there is something wrong with the room light circuit
Does anyone has the lighting ciricuit for the room light to share ?
Thanks
15,390
Is this the stock room light? Perhaps a short circuit caused by a faulty light bulb? Or a bad fuse? Old cars do strange things.
any sifuu out there.....
i need suggestion n opinion which car better aftr modded:confused:
recently i drive iswara, bt thinking chnge into prdana or wira..
need tip how to achived dat..
thinking about 450hp..
im newbie in dis forumm:confused:
