Proton 4G13/4G15....Satria/Wira/Saga
retrofit1
55
1,508
New suggestion from my mechanic:
1)Change to bigger fw & skim a bit of flywheel
2)modified clutch cover and use clutch plate perdana (my clutch also habis already)
3)Lighten conrod, crank shaft & all those related internal things.(wil done by machine shop)
4)Full balancing every single rotating things.(flywheel,conrod & etc)
5)PnP
6) skim the piston head a bit.
7)Finally,remapped the ecu.( not sure about this.stock mmc ecu can be remapped kah?
TOTAL COST=RM 2100
According to him the engine will feel more torque & lighter (of course lah skim here & there:biggrin:).Any comments guys?:hmmmm:
tofu_manic
1,342
91
5,148
wondering, y want to skim piston head? u mean skim engine head?
mite as well throw in oversized 4g15 pistons, or if budget allows, a stroker kit since evrything will be torn down
those stuffs u mention are good stuffs hehe
retrofit1
55
1,508
My mechanic A said if I want to do stroker kit, the engine kosong price for 4g15p back here in JB is expensive nowdays.Around Rm 1700 to RM 1900.Plus upah everything the total cost would easily reach Rm3000++.He mentioned that there are possiblity for engine to overheat during long journey.Is it true?? So he recommend to me those lightened & blancing things.Plus I dont have to register for engine upgrade or punch my engine block.
But my mechanic B are willing to do this stoker kit things for RM1800 only.Plus new FW & clucth the price is around RM 2300.
Now...both method are within my budget.But which one the best should I choose?Guys help please....:adore::adore::adore:
tofu_manic
1,342
91
5,148
No, with a stroked 4g15, it wont overheat...if not habis liao powerzone kenak sue by those 4g15s that got 'stroked' by them, if still worried, just put in a twincore radiator to improve cooling
difference between a stock 4g15 and a stock 4g13 is obvious, and with a 4g15, it would be a better platform to start modding, this is my opinion
since the choice is only between these 2 engines, u will have to mod the 4g13 quite a bit to just match the stock 4g15...so for others here, dont need to mention 'if modify kao kao 4g15 baru can match stock 4g92/93' because threadstarter is only contemplating on doing up these 2 engines
retrofit, mebbe u shud go find the same car with urs, but with a stock 4g15 inside...then this may help u in making ur decision
just fyi, changing to a larger flywheel does not make u go faster
retrofit1
55
1,508
Thanks tofu,maybe you are right,I should test drive a satria with 4g15 engine first.Lighten the internal thing wont bring any bad side effect kah?:hmmmm:
tofu_manic
1,342
91
5,148
that one not too sure as never did it
all i noe is that after lightened, then it has to be balanced...and also cannot be lightened too much, and also cannot cincai choose where u want to lighten, it has to be on areas which face less stresses
Don simply skim here and there. If you dismantle everything then cylinder head will need to skim a bit which will result in slightly higher compression.
If you simply skim, then the balancing will be quite difficult to do. To quote someone from another form : Imagine you're holding a brick on a string. If you start to spin the brick it'll move right? You should be able to feel the forces of the spinning (I think it's called intertia?). Imagine if your brick was slightly off balance and you spin it, the spinning wouldn't as smooth and you'll probably experience wobbling.
Take your wheels for example, if you don't do balancing you'll feel some major wobbling at certain speeds. It'll damage something eventually if you don't fix the balancing right? What if you had already skimmed a bit off your wheel? Balancing would be pretty difficult.
I think if you're gonna mod the engine, don't just skim skim skim, you can lighten with aftermarket parts (like lightened crank pulley, etc) but skimming the original.... that one I seriously doubt its reliability. It was designed to function a certain way, changing the way it functions without changing it's material isn't quite safe me thinks.
fstr
7,000 RPM
7,935
954
3,213
Sahara Desert
aiyah u all so mafan skim laa, potong laa, stroker laa..apo2 laa...
just buy some hicams, put some webers :biggrin:, skim da head, port da head (DIY laa :sleep:), LCP da fella :sleep:
then u can tapau most mildly modded 1.6s d maa :adore:
retrofit1
55
1,508
Aiyo boss dont want to tapau anybody lah boss.Just want add some shiok to my ride.:biggrin:
Just want to ask to those who have done the stroker kit.Do you guys punch the engine number or register with JPJ? Thanks.
carlyap
728
why not come down to klang do your stoker kit and New FW and clutch.... much much more cheaper than others place.........
tofu_manic
1,342
91
5,148
only changing block then need to register
registering it properly will give you a peace of mind whenever u drive ur car...dunneed feel nervous when see jpj car ka, jpj block ka, trust me it is worth it to go through the hassles for a complete peace of mind
insurance evrything all will be ok, as long as u register
punching number will have its risks...if do a bit not cun, how? can do la, but got risk...
oh well...my 0.02 ringgit onli hehe
K_Takuya
Moderate Moderator
Sep 1, 2005
1,954
153
Limau bali,Ipoh
Hi bros,
I have a question thats sway away from the engines topic, sorry. Currently im travelling a lot. This week in a day i drove about 600km. when im about to finish my journey, my car starting to jerk in the last few hundred km. its getting worse when i almost reach home. Opened the hood and found out one of the plug cable was loose. After fixing it, the jerk was gone and all ok. But theres a smell from my battery and i found out that the water inside the battery is boiling hot untill steam coming out from it! i thought it maybe because of my journey but after i shut the engine and on it back for a while, its started boiling again...its the same for the day next..
Please help me, whats happening :confused:
Thanks...
SkYwAlKeR
Over 10,000 RPM!
10,139
300
5,183
ePoh ~ malacca
stroker kit (complete crankshaft, conrods, pistons) cost around 1k or below if ur mechanic knows where to find... engine block u try find from workshops lor... they will sell them off dirt cheap, below rm500 definitely can get.... but the problem is most of them are without documents... hence, u are forced to punch the number....
aiya unker, ur previous kembara piston how leh??... vr high compression rite??... :P
if u have letter/document/AP, its better to go and register at jpj lor...
Hi bros,
Thanks...
check if ur battery terminals are connected properly or not... check the voltage value engine switch off/on... check alternator if it is overcharging or not (by refering to ur voltmeter)....
carlyap
728
How much boss? Location?:burnout:
a fren of mine overhaul his engine almost complete change all the parts only used back the block and head... cos around. RM 2k also polish the head and skimm block. engine moulding all change....
klang jalan kapar. pm me if interested.
The BMW 320i will now be available in two new variants that were recently introduced by BMW Group Malaysia, the 320i Executive Edition and the 320i M Sport, that will be available nationwide from 2 April onwards.
Both variants will be powered by the 2-liter four-cylinder mill that produces 156hp. As with all current BMW models, both the new variants will feature BMW EfficientDynamics that includes Brake...
