- Joined
- Mar 24, 2009
- Messages
- 17
- Points
- 1,501
Signca 2 Way Alarm With Turbo Timer + Security TouchPad* and Remote Start With the world's Coolest 2 Way Remote !
Dear Brother and Sister of Malaysia !
We are proud to bring you the ONE and ONLY 2 Way Alarm with turbo timer + Security Touch Sensitive Touch Pad + Remote Start with the World's Coolest 2 Way Remote IN Asia !.
* We are The ONE and ONLY company In Singapore and Asia to have the Auto Alarm with Security Touch Pad !*
Alot of customer has been asking us during the install and demo about our Quality Product. Yes ! We are having the exact Same Model found at www.zenesisalarms.com Model ZN-502 ! For those that know what SEMA in the United States is about, you will know our product is of high Quality and the Finest technology found in one of the World's finest makers of finest Car alarm and remote Starter.
( All purchases comes completed with 1 x 2 way remote and 1 x 1 way remote )
* 1 way remote works exactly the same as 2 way.*
Reserve one before it is being grabbed up !! Tested on Subaru WRX / STI , Mazda , Mitsubishi , Honda and more !!
During our first batch, all Unit was grabbed up in only less then 1 week and we already have reservation on our lists.
Please note that we will only Reserve the unit for only 1 week. After which we will have to give it up to others on the waiting list.
* Thanks for your understanding *
Pricing ( Comes with 1 Year Warranty )
Currently our Malaysia Exclusive Retailer and Installer is at KL.
It will be best to contact them directly for the best price =)
ADDRESS
33 & 35, Jalan PJS 11/7, Bandar Sunway, 46150 Petaling Jaya, Selangor, Malaysia.
TEL NO
+ 603 5636 9063
Look for Calvin or Ah Hing
* You are able to get your own bypass from your local installer / shop if you choose not to get our bypass kit.
----SPEC----
Key Features
Technology And Design : U.S.A
100% Made in Korea and uses Mostly Samsung Parts !
* Bright backlit liquid crystal display(OLCD Powered by Hyperactive LEDs)
* Starter Kill
* Remote Start
* Ignition door lock
* Alarm
* Keyless entry
* Auto / Manual Transmission
* Diesel Glow Plug compatible
* Parking Lights
* Remote Paging
* Remote Start Engine run time
* Programmable 2nd IG/ACC/Starter
* Valet by Key/Remote
* Automatic Tach Sensing
* Alternator / Voltage Sensing
* Code hopping
* 2 x Aux outputs
* 2 x Aux inputs
* Dual Shock Sensor
* Parking brake input
* Active / Passive Arming
* Siren
* Trunk Release
* Trunk Trigger
* Door Trigger
* Parking light trigger
* Hood pin trigger
* Built in turbo timer
* Long/Dual Pulse of Lock/Unlock
* Temperature Display indicator
(Fahrenheit/Celsius)
* 6000 ft. (open range) - Radio at certain areas or jamming might affect the range
* FORTIN CANBUS RS232 data port
* Clutch bypass
* Factory rearm/disarm
* Built in TRANSMITTER Antenna
* UNIQUE remote design
* Clock Display indicator
* Transmitter battery level indicator
* Alarm notification paging by customer
chime or vibrated mode
* Remote on HOLD - Meaning HOLD the button so any accidental press will not activate its functions on the remote.
----SPEC----
*Previously Original Security Pad Usage.
The pad will blink on the number from 0 - 9 in order and user will have to knock / tap on the windscreen to select the number which is the passkey.
This video shows what the South / North America users are needed to do to unlock the door with the Security pad =(
*The Newly Updated Security Pad Usage.
The newly updated Security Touch pad that is touch Sensitive ( No Knocking or tapping ) on the windscreen .Just touch the windscreen is all you need =)
This Video shows the Touch Pad in action =p
This Video shows the Cool Remote in action with Remote start, locking and unlocking and the status feedback. The Remote goes into blank standby screen like Handphone and will only light up when they is a feedback or when button is pressed.
Getting the signca 2 Way Alarm system, you no longer have to worry about the keys being locked in car , Lost of Remote or Faulty Remote.
The spare 1 way remote is included which does not required to be purchased ( Some seller requires customer to buy for the spare :? ) or worried that no spare remote to use when the 2 way is spoilt / being repair, you can even use the Touch pad as remote if you sway sway 2 remote is lost.
Global Autotech is the first in SINGAPORE and Asia to have this Security Touch pad Technology which you will not find it anywhere in Asia and wont have the same as the one sitting next to you when makan Bah Kut Teh at Klang or when relaxing at stations outlet !!. Be Unique ! So grab one today =)
Our 2 Way and 1 Way Remote will truely amazed you !
Shipping will be using Fedex International which will reach you in 2 days time after payment is confirmed.
Credit card payment can be arranged.
Groupbuy is avaliable ! Please email us for the best and most attractive package for your Club.
Please sms or call K.C @+65 82589109 for enquires or technical issues .
For Malaysia , Please call or Email to [email protected] for any inquries !
Bump: Picture of the Remote and Security Touch Pad
2 Way
2 Way - Optional
1 Way Included
Security Touch Pad
2 Way
2 Way - Optional
1 Way Included
Security Touch Pad
Bump: Key Features
Global Autotech – MMR-50 Product Specification
* Bright backlit liquid crystal display(LCD)
- The Remote is having backlighted OLCD Blue light which is Super Bright during the nights. YES ! SUPER Bright . .
* Starter Kill
- This Features will disabled the starter when the alarm has been activated. Our Main Brain is programmed to disable the starter also if you have remote started your car or by manually. This Feature is only found in our system compare to our competitor as this is to prevent user from accidentally crank their engine again. Thanks to our Alternator / Tachcometer Sensing Technology .
* Remote Start
- Remote Start can enabled manually if you want to start and cool your vehicle before you get to it OR by timer setting which will automatically remote start your vehicle at certain time set if you are overseas and needed to warm your vehicle daily.
- This is a great feature where once you have started your vehicle and the foot brake is stepped , the door will auto lock itself. Some competitor doesn’t even have this safety feature. This can be disable / enable by Remote.
* Alarm
- This Feature can make your Remote control like an Alarm clock where time can be set to trigger the Remote Control to beep / Vibrate once the time set is up. Good to remind you like parking timing and appointment.
* Keyless entry
- This is commonly used by many company in a way or another. Some will state that it is keyless entry in a form of like Transponder , unlock by original keys , unlock by remote etc without the need to slot your key on to the door and unlock means keyless entry… For Global Autotech, it is Our Security Touchpad for unlocking / locking without the need to have the keys OR Remote for unlocking and locking.
- Our Quality Product is compactible to Auto / Manual Vehicle. It is even compactible to vehicle that is CNG and Diesel Powered.
- This is needed for Diesel powered vehicle as the remote start needed to warm the glow plug before the cranking starts . This is to prevent the starter from failing.
* Anti Grinding Feature
- This Feature is much like the starter kill but with the ablilty to auto disable your starter from cranking once the sensor sense your vehicle is started. This features only available in our Alarm.
* Remote Paging
- This features is for paging your vehicle when you can’t locate your vehicle in a big carpark or can’t remember where your vehicle is parked.
- Our Remote start run time can be programmed to run from 5 mins – 25 mins. Some competitors doesn’t even have this feature.
* LED on antenna
- Our Antenna has a built in SUPER bright Blue LED that shows you the Alarm status.
- This feature is able to programme to another starter. Some Competitors Doesn't have this feature.
- This is valet mode. Valet mode is useful if your vehicle is sent for servicing, washing, polishing which you do not want the alarm to trigger off if the user who is servcing your vehicle does not know how to disable or acknowledge it. The Valet mode can be enabled by Remote and Keys and off by Remote only. Some competitors has only one remote and the valet mode can only be enabled by that remote only.
- This is mainly used on Convertible Vehicle which can set to open the Convertible roof once the engine is started.
- This feature are found in our product only. It will sense and stop the starter if the vehicle is started to prevent your starter to keep cranking during remote start . Some competitors doesn’t have this sensing technology feature and are having only Remote start time which the product will keep cranking till the time programmed in the mian brain is up .
* Code hopping
- Our Product has code hopping in our main brain unit that will prevent thief from copying or duplicating using remote sensing machine to unlock your vehicle or hijack your vehicle.
* 2 x Aux outputs
- Our Product have 2 AUX Output to control window module or mirror module once activated. Some competitors only has 1 AUX Out and no options on Input.
* 2 x Option Inputs
- Our Product have 1 additional Option Input for microwave / unltrasonic sensor. Once the sensor triggers, it will sent the data to our main brain which will trigger the alarm and parking will flash. The other Options Input is already used on our Shock sensor.
* Dual Shock Sensor
- Our Product comes with Dual Shock sensor control unit which have the options to set the warning sensitivity and alarm trigger sensitivity seperately. Some competitors only have 1 options which is the warning and alarm sensitivity which is controlled together.
- This is an feature that will notified the user if the Dome light or parking is not switched off when the vehicle is alarmed.
- This Features can be enabled to have the vehicle autolock the door when the Remote is accidentally pressed while no doors are opened and autolook the door when the last door is closed but user did not arm the vehicle in 25 secs. The vehicle will beep and chrip with parking light flashes every 5 secs and on the 5th occurrence, the system will auto lock the vehicle and arm it.
* Remote Lock
- This is only found in our product which the user can have the options to enable hold all the button to prevent any accidentally pressed command.
* Trunk Release – Optional
- Our product comes with Trunk Release command which will release the trunk when pressed. This feature only works if your vehicle comes with the Trunk Release module.
* Trunk Trigger
- This feature will trigger the alarm when any attempts to force open the trunk by thief. Some competitors doesn’t have this unique features of the separate sensing trigger on trunk.
* Door Trigger
- This feature will trigger the alarm when any attempts to force open the door by thief
- This feature will trigger the alarm when any attempts to on the lights when the system is in armed state.
* Hood pin trigger
- This feature will trigger the alarm when any attempts to force open the bonnet by thief. Some competitors doesn’t have this unique features of the separate sensing trigger on bonnet.
* Anti-Hijack
- Our product has an Anti-Hijack ( Panic ) button which will Trigger the Alarm which will then kill the engine if car is being Hi-jacked and cranking will be disabled.
- Our product has an inbuilt Turbo Timer of its kind. Our turbo timer is able to set the turbo timer run time which some competitors are having a fixed timer run time.
- This is found Only in our product which the door lock and unlocking time pulse can be set. You can set it to lock or unlock ranging from 0.3 secs to 3.5 secs before the door will lock or unlock when Remote is pressed.
- Our product have long range of up to 6000 ft.
* RS232 data port – FORTIN / CANbus Module
- This feature is only Found in Our System which is fully compatible with Fortin CAN and Immobilizer bypass module. More Information regards to this One of its kind integrated security features only found in our product, please go to :
http://ifar.ca/en/news/29-zenesis_alarms_and_remote-starter_now_support_fortin_2-way_data-link.html
* Clutch bypass
- Another feature found in our systems is the Clutch bypass. This features enable the vehicle to bypass the clutch for remote starting only. Some competitors who doesn’t have this feature will advise the customer to modify away the need from the original setting of stepping the clutch before cranking inorder to use their remote start functions.
- Our Antenna has an built in Transmitter for 2 way communication. Some competitors have separate antenna for different usage.
* SLIM UNIQUE remote design – Optional 2 Way
- This is optional on the 2 Way LED remote that is Slim , Unique and SUPER Small.
- The Remote will Display the Clock time.
- The Remote will Display the Battery Level.
- The Remote can be set to chime or to vibrated mode
* 2 year battery life (7300 entries) – Optional 2 Way LED
- This apply to our Optional LED 2 way Slim Unique Remote.
Bump: That is how thin the 1 way remote is and the optional 2 way Remote =)
ADDRESS
TEL NO
+ 603 5636 9063
----SPEC----
Key Features
* Starter Kill
* Remote Start
* Alarm
* Keyless entry
* Parking Lights
* Remote Paging
* Code hopping
* 2 x Aux outputs
* 2 x Aux inputs
* Dual Shock Sensor
* Siren
* Trunk Release
* Trunk Trigger
* Door Trigger
* Hood pin trigger
* Clutch bypass
----SPEC----
2 Way
2 Way - Optional
1 Way Included
Security Touch Pad
2 Way
2 Way - Optional
1 Way Included
Security Touch Pad
Bump: Key Features
* Starter Kill
* Remote Start
* Alarm
* Keyless entry
* Remote Paging
* LED on antenna
* Code hopping
* 2 x Aux outputs
* 2 x Option Inputs
* Dual Shock Sensor
* Remote Lock
* Trunk Trigger
* Door Trigger
* Hood pin trigger
* Anti-Hijack
* Clutch bypass
