Permanent Deposit or permanent paint damaged - Rescue OPTI COAT by KC the Detailien
kc2
My childhood buddy has been asking me to detail his car for a long time, He has been told by many & mostly the northen service center Technical Advisor - that car need to be polished every year, otherwise it has no protection...
Polish for protection - definately is not the truth
the very moment if we allow any thing to rotate or surface comes into contact by certain polishers or compound.. our paint will be definitely get polish off little by little.. very soon we will endangered our clear coat
where most of the paint damages come from our washing instead & not the environment, consistently Technical advisor insisted he must send for a polishing job r.... and often I explained all over again & showed him. so when he came down to KL ...I took my time to show him how to wash - weekly in 20 minutes & wash in another 10 minutes.
and he call me again, saying car now really need to be polished.... what happen to his last Citroen now happen to his new ride ......
where as permanent Deposit in wikipedia means
The permanent of a square matrix in linear algebra, is a function of the matrix similar to the determinant
a white stain on my car after it dried, from a ceiling leaks
more permanent pic
Fixed deposit
Fixed deposits are still the most popular form of “investment” quote wealth planner
staining may be caused by mineral-laden water dripping from the overhead concrete surface
car clear coat damaged / staining caused by mineral-laden water drips
Standard Chartered's Fixed Deposit is a high-yield, no risk deposit investment ... Earn higher interest for cash deposits on a fixed basis
he often tries to avoid this by using a remedy that ended up more damage
after many many hours of paint leveling & correction work carried out stringently
it is inspect under the sun for any flaws
This damaged done little by little by a dripping from a concrete roof leaks.
Once bitten twice shy - Famous song by the Wham
Avoid the Problem
some precautionary taken by owner but subtly again - little by little drags of car cover - causes lots of friction & ended up in more damage - swirls every where
more damages done - even without notice by the onwer
get to work
your immediate attitude will resolve much damages later
more
swirled seens under the sun
wheels before
the most contaminated place to begin with
removing tire dressing
if this silicon based dressing often get wash away by rain & splattered to the wheels well & side panel
and often many often opted for a quicker gratification by using harsh Wheels brightener / Super Degreaser that are acidic & corrosive if it is not rinse away immediately & more over it will subtly harm the wheels coating..
removing contaminant is easy when u agitate with Alien clean, a polymer based cleaner & brush away
close up
agitated & loosen up
moving on to engines
ta da
now we can clean without damaging anything
before
before
after alien clean
after a long bath
Paint decontamination begins by Alien Juice as lube & claying it off
whitish stains before
Alien Juices
wipe away
rinse off immediately
repeat of it is necessarily
ta da
before
after alien clean
swirls from car cover
close up swirled up
more
rear bonnet
before paint correction
after polishing
after 2nd passes
remember before
ta da
before under at sun shot
after sun shot
close up
before
Now
another permanent contamination rescue
before
after
before
ta da
how from a coal
now into jewel
interior a quick wipe with alien OC
before
now
I found out his mutli purpose cloth & gonna to replace it with a new MF to prevent history to repeats itself
multi purpose
he often uses it for both in & ext of the car
now it is replace by
I often suggest a different colour coat for separate the in & ext contaminations
some departing pic
reflection & gloss restores
the rear
paint redefine again
Parting pic
before rotting away
[/IMG]
but now sparkling like a diamond
the damaged
after resuscitation rescue
many hours later
ta da
remember before
now
what was damaged
but now is restored & Permanently coated with Opti coat
thanks for view yet another detailien's trials
Re: Permanent Deposit or permanent paint damaged - Rescue OPTI COAT by KC the Detaili
Perfect!!
Really a nice job done KC!!! Really Master of Detailing!
Optimum Power Clean Really Great tool to use. I tried it at TitanRev's place,
really useful and effective. He taught me a bit on how to use OPC xD
Would wanna buy one too! :biggrin:
really awesome..my dream car detail by sifu!!!
Sifu KC,
OPC really did an excellents job there....removed all the stubborn stain!
bera (Yesterday), Dayline668 (Yesterday), es2611 (Yesterday), huzaimi (Yesterday), Supra_Fanatics (Yesterday)
thanks to all my buddy for all your cheers along the way :itsme:
Perfect!!
HI Es2611
U too can do it! join us in our next hand on
Thanks Supra Fanatics
for your kind words
glad u discover something new...:nurse: getting the remedy for all your long after stubborn stains removed :listen:
HI SS12b
u too can do it....for it takes a little patience & plenty of passion :driver:
Sifu KC,
Thanks buddy...yes the alien juices work again :wavey:
Amazing.... As usual...
:wavey: A-W-E-S-O-M-E
C'est fantastique comme toujours! Bravo!:wavey:
Bonjour
Cava
Merxi :wavey:
What mouth watering results!
Thanks Doc
You too are doing it....now that u know
it only takes a little patience & plenty of passion
Thanks
bro, what do i need to remove swirl and light scratch on my freshly paint car. just ONR alone can do the work? or i need some polishing and waxing using any product?
HI buddy
if it is newly painted car I will suggest u to let it cure for 3 months prior polishing or waxing (aka paint to be dried) About 90% of the thousands of Car Waxes formulated today contain significant amounts of petroleum distillate, if it placed on yr new undried paint - it may affect your paint coat.
So washing with a good PH shampoo till it cured is vital - Eg Alien no rinse wash Aka onr...it will leave a coat of polymer after u washes it till yr paint cure
then come and join me in my clinic and learn how to correct yr paint
For light swirl and scratches using Optimum Hyper Compound or Optimum Hyper Polish that KC normally uses might be too much removal of paint. I recently switched to GPS for my biannual polishing sessions. Good for maintenance polishing and also protects. Zero dusting! Can be used by hand or machine.
ooo gps can be used by hand?
i wonder how the effect will be
To be really honest here, the glaze aspect of GPS can have a filling effect when applied by hand or not worked long with a buffer. It produces a high gloss, wet-looking shine.
As a polish, GPS can remove minor defects with pad choice, pressure, and a longer work time, while still finishing like a finishing polish.
thanks buddy
why should I be finding the answer when the answer is here
it can be hand polish too
what is GPS?
Glaze-Polish-Seal....sort of an AIO (All-in-one)....
Correct! Its indeed an AIO. Like most AIO out there... working by hand will be disappointing & since modern day clear coats appears to be harder than traditional single stage paint, working by machine is recommended. If worked by hand, you will feel very tired plus it will just fill in the defects and you will see again those defects after a few car wash sessions.
