bro, how to check the spacer balance or not?? my disc still ok bro, coz when i use with standard rim, there not problem one.Joeker said:First, Check if the spacer is balance or not. During cruising speed, does steering vibrate slightly?
Then, check if disc has warped or not. (if its warped, need to skim)
If steering virbates even slightly, if hints of the spacers being unbalance. Need to do on-wheel balanacing or remove the spacers.dimetri86 said:bro, how to check the spacer balance or not?? my disc still ok bro, coz when i use with standard rim, there not problem one.
