Original Japan Pivot 3 Drive Flat Throttle Controller to let go !
Suitable for Civic FD 1.8/2.0 or new Stream with wire hardness no. 4A provided.
Item sold to a lucky buyer !
Specs:
3-drive · FLAT features
Ultra-thin Controller:
Our 14mm FLAT model can be installed just about anywhere without interfering with the your interior design.
Mode Memory
The mode when you start the engine is selectable; the "Same as last" mode or "Normal" mode.
3 Modes with 12 steps:
Possible to change between three modes: SPORTS mode (with 7 steps) for higher acceleration response, ECO-mode (with 5 steps) for lower response and NORMAL mode for standard response.
Acceleration Monitor:
Opening % of the accelerator (amount of depressing) are displayed and it is convenient for the eco-driving etc.
Easy Installation:
Easy installation using car model specific coupling harness.
Initial Settings:
Initial settings can be made for each type of car making it compatible with a wide range of models.
Digital Circuitry:
The high-speed circuitry signal output is not affected by temperature or noise and hence guards against troubles and failures.
Normal Control when in Reverse:
When the vehicle is put into reverse it will automatically return to normal acceleration (wiring where necessary). However, usually when using reverse the degree of acceleration is at most about 10%; in this range there is hardly any change so it is not necessary to wire for using reverse.
Safety System:
The acceleration mode will automatically be returned to "Normal" if the product should break or fail, or if the two signals should separate.
Details specification can be viewed at Throttle Controller "3-drive Series" 3-drive
Retail Price: RM800~RM900
Now Selling: RM300
Reason For Selling: Demoding
Interested kindly call, sms or whatsapp.
Preferably COD around Ipoh area but postage can be arranged within Malaysia.
Specs:
Mode Memory
Easy Installation:
Initial Settings:
Digital Circuitry:
Safety System:
Now Selling: RM300
