|WTS|Pivot 3 Drive Throttle Controller, Pivot 3 Drive flat, AT drive,Specific harness
jpoplover
7,000 RPM
7,726
1,410
Nilai
|WTS|Pivot 3 Drive flat, AT drive,Specific harness
Pivot 3 Drive FLAT Throttle Controller
Ultra-thin
Controller
Our 14mm FLAT model can be installed just about anywhere without interfering with the your interior design.
Mode
Memory
The "Same as Last" mode allows you to re-start your engine in the same mode as last time.
If you wish to start the engine in "Normal" mode, wiring can be done to IGN.
3 Modes
Possible to change between three modes: SPORTS mode for higher acceleration response, ECO-mode for lower response and NORMAL mode for standard response.
12 steps
In the SPORTS mode, seven step ECO mode is a detailed adjustment of 12 all steps of five steps.
Acceleration
Monitor
Open times of the accelerator (amount of depressing) are displayed and it is convenient for the eco-driving etc.
Easy
Installation
Easy installation using car model specific coupling harness.
Initial
Settings
Inisital settings can be made for each type of car making it compatible with a wide range of models.
Digital
Circuitry
The high-speed circuitry signal output is not affected by temperature or noise and hence guards against troubles and failures.
Normal Control when in Reverse
When the vehicle is put into reverse it will automatically return to normal acceleration (wiring where necessary). However, usually when using reverse the degree of acceleration is at most about 10%; in this range there is hardly any change so it is not necessary to wire for using reverse.
Safety System
The acceleration mode will automatically be returned to "Normal" if the product should break or fail, or if the two signals should separate.
Pivot AT drive(red one)
AT-DRIVE makes it possible to easily make changes the shifting point of the automatic transmission; thus providing the perfect drive for a variety of styles from sports driving (high rpm shift) to eco-driving (low rpm shift).
Pivot Harness
Pivot 3 Drive FLAT Throttle Controller Price(with harness): 840
Pivot AT drive : RM750
Harness Price: Rm280
Warranty: No
Item condition: New, got stock
SMS/CALL 0166383725 For get more info
name: Y.H.LIM, jpoplover, joshua lim
Seller location: Negeri Sembilan
email: [email protected]
Dealing : 1. skynet
2. COD: All KTM station between MID VALLEY KTM station and seremban ktm station
3. COD: Seremban
yiloong77
213
Bro, Nice Item. Free BUMP for u.
PM me the best price of the P3D for Civic FD2 2.0S (07). Thanks.
Supra_Fanatics
Beyond 20,000 RPM!
20,685
3,998
Hi bro, I have read your catalog but I did not see Altis 2005 model in car model section but since toyota wish is using same engine as Altis (1ZZ-FE), Can this product be use by Altis 2002 - 2007 Model?
Price is RM780 total or is it added up with Harness is RM780 or RM1060?
Please pm me. TQ
jpoplover
7,000 RPM
7,726
1,410
Nilai
Bump~~~
---------- Post added at 05:27 PM ---------- Previous post was at 11:57 AM ----------
bump new item added
jpoplover
7,000 RPM
7,726
1,410
Nilai
Re: |WTS|Pivot 3 Drive Throttle Controller, Pivot 3 Drive flat, AT drive,Specific har
bump~~
jpoplover
7,000 RPM
7,726
1,410
Nilai
bump~~~
jpoplover
7,000 RPM
7,726
1,410
Nilai
bump~~
---------- Post added at 03:21 PM ---------- 6 hour anti-bump limit - Previous post was at 12:45 PM ----------
bump~~~
jpoplover
7,000 RPM
7,726
1,410
Nilai
bump~~~
jpoplover
7,000 RPM
7,726
1,410
Nilai
bump~~~
jpoplover
7,000 RPM
7,726
1,410
Nilai
bump~~
jpoplover
7,000 RPM
7,726
1,410
Nilai
bump~~~
jpoplover
7,000 RPM
7,726
1,410
Nilai
bump~~
jpoplover
7,000 RPM
7,726
1,410
Nilai
bump~~
jpoplover
7,000 RPM
7,726
1,410
Nilai
bump~~
jpoplover
7,000 RPM
7,726
1,410
Nilai
bump~~~
jpoplover
7,000 RPM
7,726
1,410
Nilai
bump~~
Ok - so here's what I do to wash, polish and wax my car. Ages ago I bought a Zymol starter pack and it came with everything I needed. Zymol and another brand called Swissol are very upmarket waxes and polishes. You may feel they're a bit extreme for your car - and in the great scheme of things - they probably are. But I'm a believer in "you get what you pay for".
It all comes down to how much you love your car, your personal budget and preference. For example - the wax & polish I like...
