BMW vehicles are designed to require service less frequently than other makes, allowing you more time on the road and less time in the shop. Bimmer drivers get to avoid the 3,000 mile oil change and instead only need an oil service every 7,500 miles for their Intermediate Oil Change and Oil & Safety Service appointments.
How is oil for BMW vehicles different from oil used in other makes?
While many care makes can use natural oils, Bimmers require synthetic engine oils, with some models having different needs than others. Synthetic oils are synthesized with chemical compounds in a controlled process, eliminating contaminants. Natural oils are refined from crude oils and can contain contaminants that made it through the refining process.
Synthetic oils, though more expensive than natural options, allow you more mileage between oil changes, perform better at lower and higher temperatures, and also are designed to help clean your engine, keeping it free from build-up.
MADE IN USA.
TEL: 012-9154001
MADE IN USA.
TEL: 012-9154001
